Page 9 of 43
Re: Flashy Clock - Yet another DEV board
Posted: 02 Aug 2019 22:08
Great work!
:bravo: :coolpics:
Posted: 02 Aug 2019 22:48
by PhilC
That's a pretty good size reduction :dualthumbup:
Posted: 04 Aug 2019 13:18
by Icky
Made one of the v3 boards yesterday and am building another today for Exxos so we can do initial tests and firmware.
Looks pretty small in the STFM. No stacking sockets.
- IMG_4252.jpg (122 KiB) Viewed 4352 times
Posted: 04 Aug 2019 20:28
by PhilC
Looking at that pic on my phone, I couldn't see the hoard without zooming in!
Posted: 05 Aug 2019 03:12
by PaulJ
Pretty cool Icky. Looks great! :) :) :)
Posted: 25 Aug 2019 17:21
by PaulJ
Here is the first cut at an .ttp app that handles most clock capabilities. Also there is a stcs.prg to drop in the auto folder to set the st date/time based on the clock.
Clock.ttp and stcs.prg should both clear hung clock chips instead of removing the battery and waiting. At this time it only handles the clocks binary mode. On the main menu it will tell you which mode the chip is in, binary or bcd. If the chip is in bcd mode you will need to re-init to put everything into binary.
Option five which displays all the registers 0-127 will not allow the user to change 0-13. These are control/clock registers that are handled by the programs other commands. You can drive over these locations but you are unable to change them.
I'm sure there are still issues but its pretty functional at this point. Needs some changes to make it more consistant but good enough to give it a test run. Report issues and I'll get them fixed. :) :) :)
Posted: 25 Aug 2019 17:49
by Icky
PaulJ wrote: 25 Aug 2019 17:21
:bravo: - Nice to see software being developed for these boards. All the more important for the STF remake. The auto folder version will be very useful.
Will have a play a little later as I am currently debugging the v3 board.
Posted: 25 Aug 2019 18:32
by PhilC
Prepare for breakage.
P.s. well done
Posted: 25 Aug 2019 18:49
by PaulJ
I expect some breakage.. you can only run it so much before you start loosing your mind. :headbang: Plan changing the nv edit termination to just hit return or esc. But its just an extra return for now. Give it hell Phil.. :mrgreen: :mrgreen: :mrgreen:
Posted: 26 Aug 2019 03:58
by PaulJ
Fixed a couple little things. Pm indicator in option 8 didn't work when clock was in AM-PM mode. Removed some debug code in option5.
Also if the clock is in AM-PM mode and its pm it will set the st as if its AM. Will fix this one tomorrow.
