So it was working fine last week. Turned on today, not so stable again :pullhair:
Been doing some voltage tests with SR98. It locks up during TTram test in TOS below 5.30V. Above that it locks up every time on YAARTTT 5th test!
I have took some scope measurements of the 5V rail with SR98...
- IMG_4036.JPG (238.09 KiB) Viewed 440 times
- IMG_4037.JPG (273.33 KiB) Viewed 440 times
- IMG_4038.JPG (279.71 KiB) Viewed 440 times
- IMG_4039.JPG (230.4 KiB) Viewed 440 times
- IMG_4040.JPG (265.94 KiB) Viewed 440 times
Then with 4,700uF added to the 536
- IMG_4044.JPG (360.71 KiB) Viewed 440 times
- IMG_4041.JPG (268.28 KiB) Viewed 440 times
- IMG_4042.JPG (267.83 KiB) Viewed 440 times
But didn't seem to change anything..
I put back in one of my PSUs which outputs 5.00V and locked up on TTram test again during power up.
I even stripped back the firmware to barebones 8MHz (no TTran etc) and it randomly resets for no reason. Even removed the clock switching and "hardwired" the clock inside the PLD to 8MHz.. didn't help either.
I swapped back to SR98, with 5.50V and now its just done a full test loop on YAARTTT :WTF:
As I have a "fly lead" on the CPU clock, I touched it with my fingers and instant lockup.. hmm.. On the STE version I had some series resistance on the CPU clock which the ST edition doesn't yet have..
The clock shows this.. could it be that simple.. (probably not)
I just noticed I have fast slew turned on still...
- IMG_4045.JPG (284.72 KiB) Viewed 440 times
So back to slow slew..
- IMG_4046.JPG (321.71 KiB) Viewed 440 times
Nothing drastically noticeable..
This is during TTram test..
- IMG_4047.JPG (302.97 KiB) Viewed 440 times
Pretty amazing voltage wise since the PLD is driving the clock directly from 3.3V rail !
So with the scope probe still attached, touching it doesn't cause a lockup now. Its done a full loop on YAARTTT.
In case anyone is wondering, IIRC, the "fast slew" which a issue on the
original TF536 (I am just trying to get to the bottom of exactly WHY)
If you set them to fast its fast on every pin and this can cause mega issues on the CPU clock line
So likely it is better having some series resistance in the clock line. But doesn't matter for slow slew anyway. It's currently locked up about half way through loop 3.. So for sure a improvement on slow slew.. Will experiment with various termination to see whats best...
I've uploaded CURRENT30SS on the STE page
https://www.exxosforum.co.uk/atari/last ... /index.htm only tested on the ST536.. But assume it work fine on the STE536 as well..
So 47pF seemed to give bad ringing and crashed on ROM CRC test. 100R looked much better on the scope.. but now no TTram found ! :roll: So was still on 5.50V. lowered to 5.30 and TTRAM found and testing OK again.. this stuff is bonkers !!
