Page 8 of 36
Re: The latest member of the family
Posted: 31 Jan 2025 14:17
JezC wrote: 31 Jan 2025 14:04 @rubber_jonnie I'll also try to test my expansion (no RTC) and see how that goes...just in case!
Good idea.
Posted: 31 Jan 2025 15:00
by stephen_usher
I'd fit the expansion, look up the address range it should have and then run Amiga Test Kit memory tester on that address range. It's possible one of the 41256 chips has become faulty. This is the least invasive test.
Then again, you know me. I try to exhaust all diagnostics before getting the soldering iron/desoldering gun out. :-) Been bitten too many times.
Posted: 31 Jan 2025 15:04
Turns out I'm a numpty.
I was looking at the bloody RAM upside down :dizzy:
So it isn't A2 and A5, it's the data in/data out pins that look all kinds of wrong. D'oh.
stephen_usher wrote: 31 Jan 2025 15:00 I'd fit the expansion, look up the address range it should have and then run Amiga Test Kit memory tester on that address range. It's possible one of the 41256 chips has become faulty. This is the least invasive test.
Yeah, I'm off looking for that now...
Also I have loads of 41256 RAM like on the expansion board so I could try piggybacking.
Posted: 31 Jan 2025 15:54
Ok, so piggybacking didn't work and when I tried to use the Amiga Test Kit to test the range where the trapdoor RAM should be (08000 to 0ffff) and it recognises it as a 512MB range, but as soon as I start the test it crashes the machine.
Interestingly though, the RTC on the trapdoor board is visible to ATK.
Posted: 31 Jan 2025 16:00
Also interesting, I found the RAM I need to do an on board upgrade if it comes to it. It was in a drawer of Atari stuff.
Posted: 31 Jan 2025 16:30
by stephen_usher
rubber_jonnie wrote: 31 Jan 2025 15:54 Ok, so piggybacking didn't work and when I tried to use the Amiga Test Kit to test the range where the trapdoor RAM should be (08000 to 0ffff) and it recognises it as a 512MB range, but as soon as I start the test it crashes the machine.
That's weird. It would suggest maybe an addressing problem where the external RAM is also being seen at a low address.
Posted: 31 Jan 2025 16:48
stephen_usher wrote: 31 Jan 2025 16:30
Definitely is.
I have been wondering if the card is not compatible with this particular issue Amiga, but that would be rather odd.
Posted: 31 Jan 2025 16:59
by stephen_usher
Maybe a short between a high and low address line, or maybe one of the higher address lines not reaching the card?
Posted: 31 Jan 2025 17:39
stephen_usher wrote: 31 Jan 2025 16:59 Maybe a short between a high and low address line, or maybe one of the higher address lines not reaching the card?
If there is I don't think it's on the card, it's super simple and looking at it with the magnifying glass, it looks just fine.
