Page 8 of 16
Re: Something experimental - A5000 mouse ball replacement.
Posted: 30 Mar 2023 11:57
by HigashiJun
Your journey to mouse balls seems not to be over yet...
8-)
Posted: 30 Mar 2023 12:13
HigashiJun wrote: 30 Mar 2023 11:57 Your journey to mouse balls seems not to be over yet...
8-)
It isn't, and I heard back from a Chinese supplier who can supply 20mm rubber coated balls, however the postage cost for samples is $36 and the balls are only 40c a unit. I don't want to order a hundred without seeing a sample TBH so that's not going to work for me.
I'll keep at it myself.
Posted: 30 Mar 2023 12:35
by stephen_usher
The alternative is that you buy these... :-)
https://www.amazon.co.uk/IKAYAS-Balls-C ... hdGY&psc=1
Posted: 30 Mar 2023 12:52
by alexh
stephen_usher wrote: 30 Mar 2023 12:35 The alternative is that you buy these... :-)
I think it was ruled they were not quite round enough nor heavy enough. And too fun.
Posted: 30 Mar 2023 13:01
Believe it or not I had these in my basket the other day, but when I looked closely at the image the seams were really quite terrible, and in fact much worse than the ones that arrived today, so I took them out, though I am considering revisiting.
Posted: 30 Mar 2023 13:10
by HigashiJun
rubber_jonnie wrote: 30 Mar 2023 12:13 the postage cost for samples is $36 and the balls are only 40c a unit.
:lol:
Posted: 29 Dec 2023 10:27
Ok, so I've decided to have another crack at this. Doing some digging and there are metal powders available for cold casting.
So I've ordered some and I'll try casting another ball, but this time a mix of resin and metal powder, the idea being that it'll add just enough extra weight to be comparable with the original ball, and will hopefully work.
I'll update when I've had a chance to give it a go.
Posted: 29 Dec 2023 10:37
by HigashiJun
Good idea and really worth trying.
Posted: 29 Dec 2023 12:02
by stephen_usher
I can't remember if you tried a 20mm ball bearing like this: https://www.ballandrollerstore.com/modu ... rome-steel
Posted: 29 Dec 2023 14:23
stephen_usher wrote: 29 Dec 2023 12:02 I can't remember if you tried a 20mm ball bearing like this: https://www.ballandrollerstore.com/modu ... rome-steel
I did, and it fits perfectly, just doesn't grip the rollers. I also tried Delrin, perfect size and texture but too light.
