Page 8 of 8
Re: exxos's H5 A3 Build
Posted: 18 Nov 2020 01:34
by agranlund
That is one pink monitor! :shock:
(That X2 sounds great in the H5 btw :))
Posted: 23 Dec 2020 14:10
AMP board in place.. took some doing... I'm probably not going to release these boards as with all the bodge wires its causing a fair bit of interface, like the hissing and whistles like on the STE audio...
- IMG_5891.JPG (397.61 KiB) Viewed 6270 times
A lot of hiss seems to be generated by the H5 amp itself.. Now I bypassed it, things are a lot better again :)
Posted: 06 Jan 2023 15:21
This board has come out of retirement. It has been designated as a test machine which will be heading down to
@Icky at some point soon.
All the later hacks have been removed and I have gone back to the
stock fixes. The "Winamp" board has been removed as there is no real use in having it on this board (H5 A3) anyway. It was only really there is a prototype for the H5C1 to fix the slightly low volume on the MIDI synth module. Which ended up in a bit of a mess anyway :roll:
- IMG_0376.JPG (349.7 KiB) Viewed 4959 times
- IMG_0382.JPG (409.02 KiB) Viewed 4959 times
- IMG_0383.JPG (146.64 KiB) Viewed 4959 times
Sound testing fine :)
- IMG_0384.JPG (153.59 KiB) Viewed 4946 times
Posted: 06 Jan 2023 18:40
by Icky
Great. Looking forward to getting my hands on it and turning it into a developer board to help with the FPGA direction :)
Posted: 06 Jan 2023 18:54
Icky wrote: 06 Jan 2023 18:40
I am still not sure the plan is there ?
Do you want me to send this board working ,as is, or do you want me to remove the MMU/GLUE/BLITTER sockets ?
Posted: 07 Jan 2023 10:27
by Icky
exxos wrote: 06 Jan 2023 18:54
Plan is to have an H5 with plug in header sockets for BLITTER, MMU, GLUE as we have PCBs to be able to plug the original chips in sockets into those headers.
Here is an example one with turned sockets but am going to move these to header sockets to be more study as the turned pins often get bent etc. but headers pins and sockets are stronger.
- IMG_2018 (1).jpeg (265.15 KiB) Viewed 4872 times
Here is an example with original chips in place
- IMG_2017 (1).jpeg (270.3 KiB) Viewed 4872 times
And then below with the Phoenix Sparkalaphobia (FPGA BLITTER)
- IMG_2019 (1).jpeg (269.98 KiB) Viewed 4872 times
This way we will have a good dev board platform for a few of us to develop and test the next step on the Phoenix Platform journey with the different chips. I also have the PSU with an extra long lead so I can have it off to the side out of the way of the board. This board is not intended to be in a case :)
Just send working as is. I'll sort out the rest.
Posted: 07 Jan 2023 11:11
@Icky do you need headers and sockets then ?
Posted: 07 Jan 2023 11:35
by Icky
exxos wrote: 07 Jan 2023 11:11
Leave it with the sockets and chips in and I’ll sort it all out as I can use the sockets on the plug-in boards.
Posted: 07 Jan 2023 11:47
Icky wrote: 07 Jan 2023 11:35
Offering to send sockets and strips not solder them in :P
Posted: 07 Jan 2023 11:54
by Icky
exxos wrote: 07 Jan 2023 11:47
Perfect.
