Page 8 of 10
Re: A new riser?
Posted: 01 Jan 2020 13:39
by terriblefire
arkadiusz.makarenko wrote: 01 Jan 2020 13:14
terriblefire wrote: 01 Jan 2020 11:24
Ok not sure how that would work. Will that setup all the HId layers and everything required? cubemx will setup everything as makefiles.
Almost finished the routing ... just need to finish the RTC stuff.
I need "only" find way of initialising usb, and reading hid...
And handling ack() from Amiga after receiving input.
I will time box it till end of January. If I will not be able to progress it I will start looking at CubeMX.
On my board at least.. amiga doesnt ack. CPLD handles everything. You just shove everything that happens into SPI2.
If you tie the ARM direct to the bus it simply will not work at all.
Re: A new riser?
Posted: 01 Jan 2020 13:51
by terriblefire
Current board... v simple.
Screenshot 2020-01-01 at 13.49.43.png (596.39 KiB) Viewed 5951 times
EDIT: This board will be open source from the outset.
Re: A new riser?
Posted: 01 Jan 2020 15:30
by GadgetUK164
That new riser is looking great!!!
Re: A new riser?
Posted: 01 Jan 2020 19:18
by terriblefire
Still in rough form. I dont usually let them out of the barn this early bit ....
https://github.com/terriblefire/cd32_riser
THERE ARE STILL BUGS IN THE EAGLECAD SO DO NOT Place an order
EDIT: Design is complete... no idea if it will work.
Re: A new riser?
Posted: 01 Jan 2020 21:15
by terriblefire
Ok... Board ordered... lets see what happens.
I'll send out 3 bare boards to anyone interested in building it / developing for it.
Screenshot 2020-01-01 at 21.14.22.png (705.11 KiB) Viewed 5910 times
Re: A new riser?
Posted: 01 Jan 2020 21:36
by kludge
I don’t remember if the DB23 has been discussed earlier in this thread, but as they can’t really be bought from the usual sources wouldn’t a VGA connector be better? Or will people assume that it’ll work with any monitor if it has a VGA port on it?
Re: A new riser?
Posted: 01 Jan 2020 21:41
by terriblefire
kludge wrote: 01 Jan 2020 21:36 I don’t remember if the DB23 has been discussed earlier in this thread, but as they can’t really be bought from the usual sources wouldn’t a VGA connector be better? Or will people assume that it’ll work with any monitor if it has a VGA port on it?
As mentioned earlier in the thread. alenppc has 300 of them or so.. we have sources.
Anyways the point of this prototype is to test the USB integration onto the riser.
Re: A new riser?
Posted: 02 Jan 2020 05:46
by 8 Bit Dreams
Have also 100x connectors left, so these are not our problem atm..
Re: A new riser?
Posted: 02 Jan 2020 06:03
by supaduper
Yep x300 DB23 pin connectors here too
Re: A new riser?
Posted: 02 Jan 2020 09:06
by terriblefire
supaduper wrote: 02 Jan 2020 06:03 Yep x300 DB23 pin connectors here too
TBH... I'm probably not even going to put a connector on my prototype build. Might only put one MCA connector on too. This board is just about getting some knowledge built up around the ARM CPU.
It may also be possible later to wire the arm up to the floppy controls (and we dont even need a real CIA) but lets walk before running .. we can always add patch wires etc.
