Page 8 of 25
Re: Terriblefire Accelerators
Posted: 12 Nov 2018 20:56
by terriblefire
Stimpy wrote: 12 Nov 2018 20:46
ICs best routed direct to power and ground plane with as short as possible tracks, ideally via right next to pad. Then place caps in small package as possible, again with vias to decouple the plane. Place vias to side of caps for smallest inductance loop, imagine viewing the board if it was sliced along the layers. Choose highest value within your budget with a decent dielectric and spec the voltage 2x or 3x the DC bias. Then more larger ceramics for bulk. This is perhaps overkill but if you ever need to do high speed designs and pass EM testing, that will get it through. Also a tip on switch mode power supplies, get your inductors round the right way!
Absolutely...
Pretty much exactly what i have here.
- Capture.JPG (161.21 KiB) Viewed 6313 times
I'm probably 1 cap short if you go by the rules of thumb.
Posted: 12 Nov 2018 21:01
Fine by me :thumbup:
Just caught up with your previous stream... You have fun routing boards! I was like that once, now its more, shoot me now... :lol:
Posted: 12 Nov 2018 21:12
by terriblefire
exxos wrote: 12 Nov 2018 21:01
I dont do it for a day job though. I sit coding all day.
Posted: 12 Nov 2018 23:06
by rpineau
This is all very interesting.
On our 68020board I did put 100nF on all power pins as close as possible to them (1206 packages). This does make things harder to route (both for me and the auto router). I might have to reconsider the number of caps and their placement to lower the count and do a you did above and place them center of the component and change them for 1uF instead.
This is a hobby for me so I never tried to hard, but if I can lower the component count and get a more stable board I'm all for it :)
Thanks guys
Rodolphe
Posted: 13 Nov 2018 03:22
by AEV80
The last few post's was excellent info guys, helpful for noobs like me.
Posted: 13 Nov 2018 08:10
by terriblefire
AEV80 wrote: 13 Nov 2018 03:22
Generally I do more than just use rules of thumb. I spice model my clock lines and capacitances before I ship a board. I chat stuff over with guys like Chris & Jamie.
Doesn’t mean I don’t screw up but that’s why I test.
Speaking of screwing up I’ve not wired up the Halt line to the onboard CPU. The 030s is wired to my CPLD. I was planning to switch off the onboard CPU with BG/BR anyways. So not sure it matters. Nothing is wired to halt on the CD32
Posted: 13 Nov 2018 09:51
by Stimpy
terriblefire wrote: 12 Nov 2018 20:56
Absolutely...
Not quite what I meant, done a image as its perhaps easier to show it.
- mod.png (783.17 KiB) Viewed 6250 times
Posted: 13 Nov 2018 10:32
by terriblefire
I see. Better to get the caps onto the power planes with as short tracks as possible. Agree.
Will apply this to my toolkit from now on.
Posted: 13 Nov 2018 11:26
by 8 Bit Dreams
last few pages was very interesting to read - excellent info guide about caps and methods to use them correctly for noobs like me. Thank You very much
Posted: 13 Nov 2018 15:53
by alenppc
I understand the worry about being overwhelmed with support requests. Unfortunately the more complex a card is, the more difficult it is to get it working (for people building them at home), and the complexity is increasing with every card you make so... there is no escaping that part :)
For end users who end up buying prebuilt boards, it's usually the people who build them that offer support, which is why I stopped mass-building and selling the 530s because I was finding it too overwhelming.
As far as the firmwares are concerned, the 328 is good and done, the 530 is looking that way too for the moment, and the 534 is close to it as well. I really love the 534 so far (especially with the NO-INT2 trick), so I vote for releasing it but your call obviously. (It also makes the 530 mostly obsolete).
