Page 8 of 10
Re: PSU bracket remake ?
Posted: 22 Apr 2019 11:37
Was this project abandoned ? If so I will try and allocate some time to starting my own version.
Posted: 22 Apr 2019 12:11
by sandord
Honestly, a lot of distractions have kept me away from this. Feel free to do your own version. Perhaps my Sketchup-version can be of help, I actually got really far with the design, only to end up with hard-to-fix bugs in the model. I concluded that I had to start all over again using Fusion 360 but learning to use that program takes quite so time. I lost focus somewhere while doing tutorials.
Posted: 22 Apr 2019 12:32
sandord wrote: 22 Apr 2019 12:11 Honestly, a lot of distractions have kept me away from this. Feel free to do your own version. Perhaps my Sketchup-version can be of help, I actually got really far with the design, only to end up with hard-to-fix bugs in the model. I concluded that I had to start all over again using Fusion 360 but learning to use that program takes quite so time. I lost focus somewhere while doing tutorials.
No worries :) Yeah if you can send me what you did , though not sure if I be able to import it into my package.
Posted: 22 Apr 2019 18:08
sandord Just send me the files :)
I thought I would just print the bottom bit and just see what happens first :)
To be continued in three hours time I guess...
Posted: 22 Apr 2019 18:16
by PhilC
Looking forward to seeing the results
Dang it!
Posted: 22 Apr 2019 18:17
by PhilC
At least it was early on in the print
Posted: 22 Apr 2019 18:44
Right, there are issues with this thing, as pointed out there is a whole there, but is not there... Now wheres Icky...
Posted: 22 Apr 2019 18:48
by PhilC
exxos wrote: 22 Apr 2019 18:44 Right, there are issues with this thing, as pointed out there is a whole there, but is not there... Now wheres Icky...
Can you see it on the model? Or just in the gcode?
Just wondering if I can edit it out?
Posted: 22 Apr 2019 18:53
PhilC wrote: 22 Apr 2019 18:48 Can you see it on the model? Or just in the gcode?
I don't really understand how this 3-D model is put together, is to be more like a drawing than a actual object which I have been used to doing...
I cannot add a hole because there isn't anything solid to draw a hole into...
For example, good hole...
Bad hole (IE no hole at all)
Seems I can drag this hole a bit at time, though it is rather tedious, will see if this works...
