Page 7 of 17
Re: PAK issues
Posted: 08 Feb 2019 21:36
by pakman
Next: Remove the U5 jumper wire, and assemble U5 instead. Try to boot.
Re: PAK issues
Posted: 08 Feb 2019 21:43
by PhilC
with U5 inserted and the wire removed from U1 also it does boot to desktop
Re: PAK issues
Posted: 08 Feb 2019 21:47
by pakman
Ok, add GAL U4 and try to boot
Re: PAK issues
Posted: 08 Feb 2019 21:51
by PhilC
It gets to desktop with U4 inserted as well but wont boot the floppy image I had on Gotek but one step at a time :)
Re: PAK issues
Posted: 08 Feb 2019 22:02
by pakman
That's weird. Check the voltage at U4 pin13, should be high. Then all outputs of U4 should be tri-stated, essentially the same as if there were no U4 at all.
Re: PAK issues
Posted: 08 Feb 2019 22:05
by PhilC
I have 4.48v on U4 pin 13
Re: PAK issues
Posted: 08 Feb 2019 22:06
by PhilC
I've also put u2 back in and it boots if that helps
Edit:
In fact it ill boot with all 5 Gals inserted
Re: PAK issues
Posted: 08 Feb 2019 22:10
by pakman
Let's fix U4 first. Get another GAL (not the U4 you are using right now), program the P4 JEDEC, and try again to boot.
Re: PAK issues
Posted: 08 Feb 2019 22:16
by PhilC
Ok, just U3, U$ and U5 inserted and it now doesn't boot
Re: PAK issues
Posted: 08 Feb 2019 22:19
by pakman
The very same U4 as before? Or a new U4?
