Page 54 of 61
Re: CURRENT PROTOTYPE STATUS (SEC 64MHz 68000)
Posted: 12 May 2020 00:49
Finally found the updated PCBs. I will try and build one up to test soon. I was planning to get 5 made up to test but the assembly place is kinda shut currently :( so I'm having to build stuff myself which is no fun at all. I cant test the SRAM boards until the new sec boards are built.
Posted: 19 Jan 2021 19:16
So I have actually had the latest PCBs for a while.. But with so many projects constantly ongoing it is hard to find time to work on this these days :roll:
I need to build one of these up as this has the I/O port for the fast ram boards is shown a couple posts up..
- sec4a.jpg (59.01 KiB) Viewed 4910 times
As shown in my
blog earlier, I just hooked up a previous version to make sure it was all working fine before starting a new build... The new build had some pins rearranged and of course the 4 SRAM IC outputs... Basically I should be able to get like 64MHz into fast-ram. I really want to see what the proper results are for this speed on a basic 68000 CPU..
One reason for the delays in this project was because the SRAM chips were incredibly expensive and the board would cost around £120 just to make... This is the reason I started a new topic about
porting the SDRAM controller from the TF330 to a new board, as it would be a lot cheaper to produce that way.. So I hope to make the fast ram as fast as possible, in the order of like 10ns, and make the board at a more sensible price. So while the booster has been around for a while, it could not really progress until the faster RAM board is completed..
In any case, I do have several of the original boards which are still untested, but I think when I build up hopefully the final SEC booster version I actually still working with one of these current fast ram boards... 64MHz speeds should be easily possible with this current setup.
Posted: 19 Jan 2021 21:20
I guess I should have found the bits before pasting the board :lol: :roll:
- Capture.PNG (1007.46 KiB) Viewed 4887 times
Posted: 19 Jan 2021 21:42
by rpineau
:lolbig:
I did exactly that last week. Fully pasted a board, starting installing all the main component, moved to the caps and resistor to realized I was missing a bunch !!!
Posted: 19 Jan 2021 21:48
rpineau wrote: 19 Jan 2021 21:42
:lolbig: :bravo: :imwithstupid:
Posted: 19 Jan 2021 21:49
So the first annoyance with this...
- 2.PNG (601.57 KiB) Viewed 4874 times
Posted: 19 Jan 2021 22:29
2nd attempt... I pushed the IC flat down on the desk to level the pins this time... I need to beep it all out next.. probably next one I do I probably print a bit more paste on the PCB..
- Capture.PNG (434.06 KiB) Viewed 4866 times
Everything beeps out :)
Need to find a PLD to solder on the bottom now.. think I might be out of them :roll:
Posted: 21 Jan 2021 12:59
So no PLD's... So your sacrifice is not in vain earlier version :2k2:
- IMG_6121.JPG (62.13 KiB) Viewed 4796 times
- IMG_6122.JPG (56.38 KiB) Viewed 4796 times
Posted: 21 Jan 2021 13:48
Pasting away..
- IMG_6123.JPG (288.58 KiB) Viewed 4968 times
Talk about inconsistencies to what is actually pin one :roll:
- Capture.PNG (1.33 MiB) Viewed 4965 times
- 2.PNG (60.42 KiB) Viewed 4964 times
This one (soldered down one) seems to be small dot is pin 1 , with the corner cut off more..
- 11.PNG (747.47 KiB) Viewed 4962 times
Assuming the small dot on the new chip, no corners are cut.. but then why have a BIG dot on the chip ? Does that mean its pin 1 or the smaller dot ?! All the corners look the same to me on this one...
- 22.PNG (672.65 KiB) Viewed 4962 times
I will have to assume the text is correct orientation and the smaller dot is still pin 1..
Posted: 21 Jan 2021 14:23
Anywhos, time for a bath with the board now..
- Capture.PNG (1.13 MiB) Viewed 4957 times
All clean :)
- Capture.PNG (885.72 KiB) Viewed 4955 times
