Page 54 of 95
Posted: 17 May 2023 10:59
by PhilC
Thanks @stephen_usher thats where I found the Cisco PSU replacement guide :D
Posted: 22 May 2023 13:04
by PhilC
My replacement power supply for the MTX has arrived today, so I've got to carry out a few mods to the MTX motherboard to allow the use of a DC PSU instead of the original AC type PSU as seen on this web page
https://archive.sundby.com/mirror/primr ... psu_dc.htm
I also removed the 32K ram that was fitted to the MTX and fitted 64K instead. Looks like this computer had an external 32K upgrade board fitted but that's long gone now. I'll have to try and locate the Jed file for a new memory GAL if it doesn't boot with the memory as is.
Posted: 22 May 2023 15:37
by stephen_usher
Yes, you'll need the new PAL/GAL The description is at the end of the manual. You'll also have to adjust the links on the motherboard.
- IMG_0682.jpeg (254.5 KiB) Viewed 1131 times
In this case (because the MTX500 was using "low" versions on the RAM chips) the top link needs to be moved so that it links middle and "4" vias.
- IMG_1461.jpeg (4.84 KiB) Viewed 1129 times
Posted: 22 May 2023 17:06
by PhilC
Thanks
@stephen_usher I’ll have to find where to track down the GAL jed file.
I’ve got it sort of working now as well
- IMG_2686.jpeg (361.04 KiB) Viewed 1122 times
I’ve got to work out what the links are presently set to as well.
- image.jpg (237.98 KiB) Viewed 1122 times
Posted: 22 May 2023 17:15
by stephen_usher
Looks like one of the 4116 video DRAM chips is dodgy. That should say "Ready", so that's bit 3.
I've attached the GAL stuff.
Posted: 22 May 2023 17:50
by PhilC
@stephen_usher its not just the one 4116, I’ll socket them all and then test and replace.
Thanks for the GAL stuff
Posted: 22 May 2023 17:53
by stephen_usher
I'd replace them with hacked 4164s as they're more reliable, run cooler and don't need the extra voltages.
Posted: 22 May 2023 18:57
by PhilC
stephen_usher wrote: 22 May 2023 17:53
I've got loads of working 4116's at the mo, otherwise I'd probably do that and am running low on spare 4164s as well.
Posted: 22 May 2023 19:59
by PhilC
Once again thank you
@stephen_usher, new GAL and 8 new 4116s fitted and we have a nice garbage free screen and 64Kb ram.
There is another error to track down unsurprisingly, the key repeat delay is pretty much zero, so pressing any key briefly usually ends up with 5 or 6 lots of that character. Should be something simple to find :lol:
- IMG_2687.jpeg (503.39 KiB) Viewed 1090 times
Posted: 22 May 2023 20:13
by stephen_usher
That'll be slightly corroded key switches. Electrolube EML down the key post and exercise the switch will fix that. It's the same as BBC Master keyboards.
