Page 53 of 57
Re: A5000 - diving in at the deep end!
Posted: 17 Feb 2025 22:09
Would still be good to get FTPc going though.
Posted: 18 Feb 2025 02:55
by HigashiJun
rubber_jonnie wrote: 17 Feb 2025 22:09
Will check later today on my A3000.
Posted: 18 Feb 2025 07:15
HigashiJun wrote: 18 Feb 2025 02:55
Thanks 👍
Posted: 18 Feb 2025 08:22
by HigashiJun
@rubber_jonnie
Ok, just checked my NIC settings:
AUN and ACCES are in ROM, but they are not enabled in the Network Configuration panel:
- AUN.JPG (577.41 KiB) Viewed 682 times
- ACCESS.JPG (695.08 KiB) Viewed 682 times
And here are the other Internet settings:
- 1.JPG (639.97 KiB) Viewed 682 times
- 2.JPG (577.48 KiB) Viewed 682 times
- 3.JPG (564.72 KiB) Viewed 682 times
- 4.JPG (610.02 KiB) Viewed 682 times
- 5.JPG (598.82 KiB) Viewed 682 times
Don't know if that helps though...
Anyway, let me know even if you have an ounce of any kind of progress.
Posted: 18 Feb 2025 09:38
HigashiJun wrote: 18 Feb 2025 08:22
@rubber_jonnie
Thanks for those, appreciate you taking the time.
Aside from the differences in IP address I'm set up the same, so I don't know what's going on with FTPc. Possibly the only other difference is that I use a HOSTS file for some local addressing, otherwise I'm using the same external DNS addresses as you too.
I'm just taking a full backup of the machine over to an NFS share using Sunfish. That will give me 2 complete backups of the boot drive locally, one on SCSI the other on IDE, and then a full backup of everything on my server, so that should give me plenty of room for recovery if I need to.
Posted: 18 Feb 2025 09:43
by HigashiJun
@rubber_jonnie
Can you try with the here attached FTPc ?
- FTPc.zip
- (225.83 KiB) Downloaded 24 times
Posted: 18 Feb 2025 11:08
HigashiJun wrote: 18 Feb 2025 09:43
@rubber_jonnie
FTPc.zip
I'll give it a go, thanks.
My file backup is still going, it may be a while...
Posted: 18 Feb 2025 13:45
@rubber_jonnie
FTPc.zip
Same happened as with my copy, it tried to connect using FTPS not FTP. No joy.
Posted: 18 Feb 2025 21:55
@rubber_jonnie
FTPc.zip
BTW I downloaded the latest version, 1.56 and it doesn't crash with AcornSSL installed from the ROOL hard disk image. I class that as progress, however looking at the manual it seems there should be options to pick from the FTPc menu, but security for example has nothing in the list and according to the manual it should have several options to pick from.
So I need to have a closer look as to why that is, perhaps delete the existing config files and start again.
Posted: 18 Feb 2025 22:37
by HigashiJun
rubber_jonnie wrote: 18 Feb 2025 21:55
Yes, I have these options available in my settings.
