Page 6 of 7
Re: MegaSTE Repair Continued - Video Noise
Posted: 07 Jan 2021 09:16
by geogeo_28
Moving around the 32MHz wire as far away as possible of the video signal did nothing.
Posted: 07 Jan 2021 15:18
by displaced
So just to wrap up from my side:
Have swapped back to the old PSU and the noise has immediately returned. Have ordered exxos’s recap kit for my model PSU, and I’ll keep the Meanwell as a nice multi-volt test supply. I’ve got a bare STE board I can use it on for tinkering.
Thanks all for your help - I should’ve just recapped the damn thing straight away, but I got swayed by its apparently decent output and the good rep that the MSTE’s PSU has!
Posted: 07 Jan 2021 15:22
displaced wrote: 07 Jan 2021 15:18 So just to wrap up from my side:
PSUs are usually worth recapping from the off, though the rest is normally OK.
Posted: 07 Jan 2021 15:46
by displaced
Yeah - don’t know why I didn’t just go for it. Always seems like a big job for amateurs like me. But I’ve done it once before on an Archimedes, and have replaced caps elsewhere with success. And PSU caps are usually nice and chunky on not especially dense PCBs - so not technically difficult, just needs a good amount of care!
Posted: 07 Jan 2021 17:54
by geogeo_28
I guess I will try an other PSU and see if this has an impact on the noise.
Posted: 07 Jan 2021 17:58
geogeo_28 wrote: 07 Jan 2021 17:54 I guess I will try an other PSU and see if this has an impact on the noise.
If your using my PSU then it has like x10 less noise than original ones, so it wouldn't make any sense if a different PSU solved the problem.
Posted: 07 Jan 2021 22:54
by geogeo_28
As expected, switching to the original PSU did literally nothing.
I guess I have to take a closer look to the video circuit. :/
Posted: 07 Jan 2021 22:57
geogeo_28 wrote: 07 Jan 2021 22:54 As expected, switching to the original PSU did literally nothing.
I don't remember if you have done this fix.. it may help on a STE anyway with your issue.. :shrug:
https://www.exxosforum.co.uk/atari/last/ ... /index.htm
Posted: 07 Jan 2021 23:56
by geogeo_28
Yup I did this fix. It removes the ghosting but not the noisy vertical lines.
Posted: 10 Jan 2021 01:55
by geogeo_28
Looking more into this issue. The white lines now starts to be visible at NTSC 60 Hz.
I suspect U401 C301712-001 is failing.
Unfortunately, I don't have a spare part to verify this hyptohesis quickly. :/
