Page 6 of 7
Re: A little bit of 8 Bit: 65XE upgrade to 128k RAM
Posted: 20 Dec 2020 09:31
Trollbra wrote: 19 Dec 2020 14:42
if i'm sure RAM/MMU are the problem, why not... What expansion do you advise ?
Personally my preferred RAM expansion is the Ultimate 1MB, as it gives you many options for different RAM configurations.
I have heard it said that it is not 100% compatible, but I haven't yet encountered anything that won't run on it, plus if you also have a SIDE, SIDE2, SIDE3 cartridge it gives you an extremely complete hard drive and cartridge/ATR/XEX solution.
As for SIO Max, if you power it off the Atari, selection of files from the boot up Atari menu is best, rather than the built in screen on the SIO Max.
Posted: 20 Dec 2020 12:34
by tzok
Try to remove EMMU and cross-wire its socket, so the computer would behave as it had only 64 kB of RAM, and if it doesn't help, try to substitute MMU with another one or a GAL replacement (in 800 XL it was a PAL chip, so GAL replacement is 100% compatible).
- EMMU_64k.png (212.64 KiB) Viewed 4833 times
Posted: 21 Dec 2020 12:35
by Trollbra
tzok wrote: 20 Dec 2020 12:34
Ok I try this, thanks ! No need to replace original resistor ?
Posted: 21 Dec 2020 14:18
by tzok
These "resistors" mounted instead of EMMU are just jumpers (0 Ohm).
Posted: 21 Dec 2020 17:21
by Trollbra
tzok wrote: 21 Dec 2020 14:18
I want to be sure I have understood correctly before starting, in first (step 1) I remove MMU and cross-wire its socket like your screenshot. If that doesn't work I replace MMU (I own 800XL MMU) without modify step 1, that's right ?
Posted: 22 Dec 2020 14:13
by tzok
Not MMU, but EMMU. This is how 130XE (ECI) boards were configured for 65XE/800XE computers.
You could also replace the MMU, with another one or a programmed GAL replacement.
Posted: 23 Dec 2020 00:38
by Trollbra
I replaced MMU and cross-wire its socket (64k native mode) like your screenshot, the same ! :?
- P1060061.JPG (500.48 KiB) Viewed 4749 times
What can I try now ?
Posted: 23 Dec 2020 10:18
by Trollbra
I don't know if it helps but the 6502 is hot !
Posted: 23 Dec 2020 14:06
by tzok
Have you tested base RAM with something more than a SELF-TEST? MT chips are known to go bad.
Interesting - you have 3 different types of capacitors in RAM BANK 1, and some sockets are rotated by 180°.
Sally (6502C) normally gets quite hot, but it also gets damaged quite often, worth to check.
Posted: 23 Dec 2020 15:36
by Trollbra
tzok wrote: 23 Dec 2020 14:06
Yes, I have the Jurgen's Sys-Check cartridge !
Some sockets are rotated by 180° ? I don't understand !?
I have already tried to replace it with another, it's the same...
