Page 6 of 15
Re: Compatibility issues with TF530/TF534 and A600?
Posted: 20 Mar 2019 19:52
by terriblefire
Booting DiagROM?
Posted: 20 Mar 2019 20:11
by kludge
terriblefire wrote: 20 Mar 2019 19:52 Booting DiagROM?
That was DiagROM. I don't know if it outputs anything on the serial port, though.
Posted: 20 Mar 2019 20:23
by terriblefire
Definitely worth checking. The green flashes look promising
Posted: 20 Mar 2019 21:09
by kludge
terriblefire wrote: 20 Mar 2019 20:23 Definitely worth checking. The green flashes look promising
So... I'm getting output more often than not, but it fails at different times. And sometimes passes checks and sometimes fails them. Bad connections?
#1
Testing if serial loopbackadapter is installed: <> NOT DETECTED
- Parallel Code $ff - Start of ROM, CPU Seems somewhat alive
    Checking status of mousebuttons for different startups:
            P1LMB P2LMB
    Set all Interrupt enablebits (INTENA $dff09a) to Disabled: Done
    Set all Interrupt requestbits (INTREQ $dff09c) to Disabled: Done
    Set all DMA enablebits (DMACON $dff096) to Disabled: Done
Testing if OVL is working: OK
- Parallel Code $fe - Test UDS/LDS line
  - Test of writing word $FFFF to $400 FAILED
  - Test of writing word $00FF to $400 FAILED
  - Test of writing word $FF00 to $400 FAILED
  - Test of writing word $0000 to $400 OK
  - Test of writing byte (even) $ff to $400 OK
  - Test of writing byte (odd) $ff to $401 FAILED
- Parallel Code $fd - Start of chipmemdetection
Addr $00000400
       Write: $AAAAAAAA  10101010101010101010101010101010
        Read: $000000BF  00000000000000000000000010111111  FAILED
       Write: $55555555  01010101010101010101010101010101
       Write: $F0F0F0F0  11110000111100001111000011110000
       Write: $0F0F0F0F  00001111000011110000111100001111
        Read: $B895BFF5  10111000100101011011111111110101  FAILED
       Write: $FFFFFFFF  11111111111111111111111111111111
       Write: $00000000  00000000000000000000000000000000
Addr $00008400
       Write: $55555:1101  FAILED
        Read: $122E0925  00010010001011100000100100100101  FAILED
Addr $00010400
        Read: $2F3F4F5F  00101111001111110100111101011111  FAILED
Addr $00018400
        Read: $00003FFF  00000000000000000011111111111111  FAILED
Addr $00020400
        Read: $00000000  00000000000000000000000000000000  FAILED
Addr $00028400
Addr $00030400
Addr $00038400
Addr $00040400
       Write: $AAAAAAAA  101010101010101FIL
#2
 @U
Garbage before this text was binary numbers: 1, 2, 4, 8, 16, 32, 64, 128, 240, 15, 170 and 85
To help you find biterrors to paula. Now starting normal startuptext etc
Amiga DiagROM V1.1 - 01-Jan-19  - By John (Chucky/The Gang) Hertell
AddressError Detected
PANIC! System halted, not enough resources found to generate better dump
#3
            P1LMB P2LMB
  - Test of writing word $FFFF to $400 OK
  - Test of writing word $00FF to $400 OK
  - Test of writing word $FF00 to $400 OK
  - Test of writing byte (odd) $ff to $401 OK
Addr $00038400   OK  Number of 32K blocks found: $07
Startaddr: $00000400  Endaddr: $00038000
- Parallel Code $fc - Start of non autoconfig fastmemdetection (as no chip found/startup check)
  - No fastmem found, Autoconfig ram NOT checked
- Parallel Code $fb - Memorydetection done
  Using $00024D00 as start of workmem (Base)
- Parallel IC! System halted, not enough resources found to generate better dump
#4
 @U
            P1LMB P2LMB
Addr $00000400
Addr $00008400
Addr $00010400
        Read:
#5
 @U
            P1LMB P2LMB
Addr $00000400
Addr $00008400
Addr $00010400
Addr $00018400
#6
 @U
            P1LMB P2LMB
Addr $00000400
Addr $00008400
Addr $00010400
Addr $00018400
Addr $00020400
       Write: $555
Posted: 20 Mar 2019 21:27
by kludge
(This is with a DIP64 68k in the adapter)
Posted: 21 Mar 2019 07:46
by terriblefire
kludge wrote: 20 Mar 2019 21:27 (This is with a DIP64 68k in the adapter)
At this point i'd put an LA on the bus to see what the heck is going on.
Posted: 21 Mar 2019 08:23
by kludge
terriblefire wrote: 21 Mar 2019 07:46 At this point i'd put an LA on the bus to see what the heck is going on.
I only have one of these, so I won’t be able to capture the whole thing. What lines should I measure, A0-A7? https://sigrok.org/wiki/Noname_Saleae_Logic_clone
Posted: 21 Mar 2019 08:30
by terriblefire
I'd be very surprised if those would see whats happening. they arent even x10 probes. :/
Posted: 21 Mar 2019 08:55
by kludge
terriblefire wrote: 21 Mar 2019 08:30 I'd be very surprised if those would see whats happening. they arent even x10 probes. :/
I have a 2 channel 50 MHz scope as well, so I could start measuring the signals induvidually :)
Posted: 21 Mar 2019 09:08
by terriblefire
kludge wrote: 21 Mar 2019 08:55
Annoyingly the spare HP1661CS on my lab floor would tell me the problem in seconds.
