Page 42 of 70
Posted: 24 Jan 2019 08:58
by Smonson
Not much. Just the schmitt trigger for the 16MHz clock, the inline resistors on both sides of it, and the capacitor on the output. I got rid of the unneeded resistor pack footprints and moved the header for the ribbon cable.
The reason I filed the corner down is because, on my ST at least, there's an electrolytic capacitor in the way.
Posted: 01 Feb 2019 21:04
by Darklord
So will these boards work with ST models that do NOT have a modulator
and/or the STacy?
If that question has already been answered in the previous 42 pages, I
apologize - I tried to hit the high points but didn't see any discussion
about it.
Thanks.
Posted: 01 Feb 2019 22:47
by Smonson
Dunno what the STacy hardware is like, but they don't need a modulator - just a socketed shifter (to remove the shifter and plug in in its place).
Posted: 02 Feb 2019 05:03
by Darklord
Smonson wrote: 01 Feb 2019 22:47
Thanks! Not sure how different the STacy is - I know it has a "Shadow" chip in there...
Posted: 10 Feb 2019 15:09
Consider this as me registering my interest in beta testing 😁
Posted: 10 Feb 2019 19:01
by PhilC
rubber_jonnie wrote: 10 Feb 2019 15:09
And considering I've just seen it on Ickys machine earlier, definitely count me in.
Posted: 11 Feb 2019 03:32
by Smonson
Thanks for the enthusiasm 😀
Eventually I will make a new revision of the board that gets rid of the PCB sandwich, and puts everything important on a single 4-layer PCB. The reason why that's "eventually" is basically I've temporarily run low on funds, and these things cost relatively a lot to put together. The postage from Oz is also pretty wild.
But there's no guarantee that will solve the remaining problem (resetting) because I can't reproduce the issue here, and thus can't investigate the mechanism that causes the bus to not be driven from the FPGA side.
I could build and send out more boards, but I think it's likely some people's boards will just work, and some won't, without shedding any new light on the situation.
I'm always keeping an eye on ebay for STFMs. If I get a second one it may enable me to reproduce the issue.
Posted: 18 Feb 2019 11:29
by vattari
You’ve got another beta tester here Smonson, if you need one (I’m in Oz as well if that helps and have a large collection I can test this with).
Posted: 18 Feb 2019 12:24
by Smonson
...Exxos talked me into it :lol: - so I'm already putting a couple more sets together. I think I have sufficient material on hand for three, assuming none of them fail testing. They're the same as the ones Exxos, Troed, and Icky have.
I can make these available for further beta testing on the understanding that there's no expectation that they will work with every machine. Plus I will have to charge 50 GBP / 75 AUD (lower because of lower postage) to cover costs.
I should have two done in a couple of days and the third one next weekend.
Posted: 18 Feb 2019 12:49
Smonson wrote: 18 Feb 2019 12:24
:lol: 8-) There's a couple of people on another group who want to know the price.. Just make sure you are not doing this at a loss..
"BETA TEST" ;) That is what I do with my stuff as well, if people want the latest stuff and accept there may be issues, then they themselves make the choice if to buy the item or not. I generally offer cheaper price for basically the beta test versions as well.. They get a good deal with the "risk" as well. Generally people here are really good anyway, just want to help support projects more than anything.
I have a stack of motherboards coming soon.. All various revisions etc. so I will test the HDMI board one you sent me on all of those.. Might take a while if the shifters are not in sockets though...Then if I come across any issues, I will try the other adapter board you sent me not long back.. I will investigate the 32,16MHz clocks as well to see if I can spot anything amiss.
Will try and do this next week, but knowing how things generally go here, each time I trying allocate some time to do something, I end up doing something else instead which has to take priority :roll: But it will get done!
