Page 5 of 5
Re: dead TT motherboard repair attempt
Posted: 19 Jul 2021 13:47
by jookie
Icky wrote: 19 Jul 2021 13:20
That's a nicer solution for the SMT boards. The through hole is a pain to desolder and clean up but Lyxman's ram board add-on works well.
Yes, that's what I've thought, and as I could swap my through hole (THT) RAM with this SMD RAM with a friend (for a price of upgrading one of his 2 MB SMD RAM for him), that's what I did - skipped to try the THT, went straight to SMD. But the real motivator here was that I couldn't find the THT chips to buy, but I could get those SMD ones, so also helped with the decision.
Great work :)
Thank you both :)
Posted: 11 Apr 2022 12:24
by Steve
Hi Jookie,
I am struggling to see where the DCU UA01 is on the TT motherboard, could you help point it out for me? Thanks
Posted: 12 Apr 2022 08:49
by jookie
I'm not currently sure if it's the left one or right one, but you could measure connections from one and other to some known chips to tell them apart. Both are C300581 chips.
You can measure pins PD0-PD7, if they are connected to UA02 (== 5380 SCSI chip, which is on the right on MB), then that chip having the connection to UA02 is UA01. My first guess is that it would be the right one (as the SCSI chip is on the right).
- mb_tt.gif (28.82 KiB) Viewed 2542 times
Posted: 12 Apr 2022 11:34
by Steve
Thank you. Yesterday I re-flowed all the solder on each surface mounted PLCC chip due to some very odd infrequent issues. Do you think it is possible that you could sometimes have a dry solder joint on one of these chips legs?
Posted: 12 Apr 2022 14:50
by jookie
Steve wrote: 12 Apr 2022 11:34
Well, anything is possible... Although there are so many sources of problems on old machines, that one cannot be completely sure :)
Posted: 09 Oct 2023 12:54
by 32bitminus
Was it ever fixed?
Posted: 16 Oct 2023 16:37
by jwd
32bitminus wrote: 09 Oct 2023 12:54
Was it ever fixed?
Just a bump, would like to know too.
Posted: 04 Jan 2025 04:35
by jookie
Was it ever fixed?
jwd wrote: 16 Oct 2023 16:37
Mine was fixed - as I wrote before. Steve's one - I have no idea ;)
