Page 5 of 12
Re: Steve's H5 A3.14 Build (Chicken Pie edition)
Posted: 01 Jan 2021 15:47
by Steve
@PhilC I might de-solder the monitor socket & put it in the ultrasonic.. I did try the good old wiggle but the colours didn't seem to change. I don't have the test equipment for checking multiplexer output, besides my multimeter.
Posted: 01 Jan 2021 17:25
by Steve
Just an update.. removed / ultrasonic'd the rgb port, re-soldered.. still yellow
I was thinking of de-soldering the r g b matrix chips and putting them back in a different order, to see if the output changes - does this sound like a good idea?
Posted: 01 Jan 2021 17:44
Steve wrote: 01 Jan 2021 17:25
If your going to do that, might just be easier to get a new chips ?
Posted: 01 Jan 2021 20:16
by Steve
Yes but it costs zero pounds and can only give me good information?
Posted: 20 Feb 2021 12:08
by Steve
Okay - I'm in the mood to try to fix my H5 yellow display finally. I'll need some pointers if possible from you kind fellows. I now have my scope! So can test things properly. Or should I just buy 3x new matrix chips for r/g/b to start with.
Posted: 20 Feb 2021 14:13
I would start with holding down reset to get a white screen and make sure all the shifters RGB bits are all toggling , then try colour test on the diagnostic cart.
Posted: 20 Feb 2021 15:55
by Steve
@exxos Okay - hopefully I've probed the right pins and gathered good data? Probed pins 6, 7, 10. R G B. Scope in auto mode.
Pin 6, red:
- PXL_20210220_154418824.jpg (304.28 KiB) Viewed 3644 times
Pin 7, green:
- PXL_20210220_154707578.jpg (307.75 KiB) Viewed 3644 times
Pin 8, blue:
- PXL_20210220_154826885.jpg (296.79 KiB) Viewed 3644 times
Videos of reset behaviour (As I'm not sure what I'm seeing, need help with understanding)
Red:
Green - same
Blue:
Posted: 20 Feb 2021 17:36
There is 3 bits for red green blue..
Posted: 20 Feb 2021 17:55
by Steve
I know it's bad to spoon feed to teach people, but I might need at least one spoon full. lol :) Am I anywhere in the ball-park with how I scoped the pins, to see these bits is it a setting in the scope? I really don't know, I'm new to this I apologize.
edit:
I may have found it, so scope pins 21, 22, 23 etc?
- index.jpg (15.99 KiB) Viewed 3627 times
Posted: 20 Feb 2021 18:04
Steve wrote: 20 Feb 2021 17:55
Yep, R0,R1,R2 etc
EDIT
Then check them on the outputs of the buffers..
