Page 5 of 37
Re: TF536 + 68000 relocator and ROM board project.
Posted: 07 Oct 2020 18:57
by JezC
PhilC wrote: 07 Oct 2020 18:30 @JezC actually I'm running low, thanks for reminding me.
@PhilC Always happy to help out ;) :lol:
Posted: 07 Oct 2020 18:58
by stephen_usher
JezC wrote: 07 Oct 2020 18:29 @stephen_usher Don't let @PhilC know you've been buying "his" 64 pin sockets...and they're nearly out of stock...
Sorry, was that the frantic clicking on the buy button I just heard? :lol: :roll:
:-D :dualthumbup:
Posted: 07 Oct 2020 19:30
by PhilC
(Moved topic to new TF536 booster section)
Posted: 08 Oct 2020 11:55
by stephen_usher
The sockets have arrived form Exxos (I'm always amazed how waterproof the packages are. Many rolls of tape died to get the packages to you.)
I've just paid the import duty on the PCBs. After shipping and duty they're working out at about £20 each. (Don't worry @PhilC the ones I'll send you will be free.)
Posted: 08 Oct 2020 12:00
stephen_usher wrote: 08 Oct 2020 11:55 The sockets have arrived form Exxos (I'm always amazed how waterproof the packages are. Many rolls of tape died to get the packages to you.)
Yeah, When I am at my girlfriends and shes packing.. the noise of the tape kills my ears.. so "weekend packages" now have darker tape, I paid more for "silent tape" it does exist, and is awesome :lol:
Posted: 08 Oct 2020 18:40
by stephen_usher
Hmmm... Hit a snag, the header pins I bought won't fit into the turned pin 64 way sockets from Exxos. The corners of the square pins foul the sides.
What pins do people usually use to fit turned pin sockets?
The alternative would be to file down every pin manually.
Posted: 08 Oct 2020 18:59
stephen_usher wrote: 08 Oct 2020 18:40 What pins do people usually use to fit turned pin sockets?
Round socket pins - round header pins :lol:
https://www.exxosforum.co.uk/atari/store2/#0132
Posted: 08 Oct 2020 19:29
by stephen_usher
Ah... :-)
Could be tricky as they add a couple of mm height and I need to make this as low profile as possible.
With the normal header pins I was going to solder them with the plastic on the upper surface and the long end going through the board. This would make the pins the requisite 3mm long underneath the board, with the board being flat against the top of the socket. Hmmm....
Posted: 08 Oct 2020 19:32
samtech make low profile pins, but they are like £1 per 24 pins strip..
https://www.exxosforum.co.uk/forum/viewt ... 437#p50437
Posted: 08 Oct 2020 20:36
by stephen_usher
OK, I've ordered some of your pin strips. If they're the same ones PhilC used on the TF536 the thin pins will be long enough going through thePCB and soldered. Just less than 3mm, which is still similar enough to normal IC pins that it should be fine in the socket.
