Re: Module ESP8266 without TF on Amiga
Posted: 17 Apr 2020 17:03
set bitrate 38400
save
reset
save
reset
We welcome retro users & hardware gurus alike! Come and join the party :)
https://www.exxosforum.co.uk/forum/
telnet 192.168.240.1 7777Code: Select all
set bitrate 38400Code: Select all
saveCode: Select all
resetYou are all set. Plug it into the amiga and use my script.kulamario wrote: 17 Apr 2020 17:16 I waiting maybe few minutes with
CMD>reset
Then I get info
Connection closed by foreign host.
So I write aginThenCode: Select all
saveAfter reset is still freeze CMD>resetCode: Select all
reset
type execute install_scriptkulamario wrote: 17 Apr 2020 17:18 This script how to start ?
Just double click and then enter , enter ... ?
I disconnect esp8266 from laptop and connect to amigaCheck that the version is the one with the baud rate of 38400..
start with ping 192.168.240.1 at a cli after a reboot.kulamario wrote: 17 Apr 2020 17:45 How to check this ?I disconnect esp8266 from laptop and connect to amigaCheck that the version is the one with the baud rate of 38400..
Install your script
I try to open site in AmiiFTP and nothing happened
How should be Led on esp8266?
My just light up for 2sec and then turn off
Have you tested your hardware?
