Page 5 of 22
Re: TF536 on A2000
Posted: 16 Jul 2020 00:52
by dalek
@matt020 have you tried the TF536 without the A2091 installed?
Re: TF536 on A2000
Posted: 16 Jul 2020 02:06
by matt020
dalek wrote: 16 Jul 2020 00:52
I didn't, I really felt that because I was having the same results as other people, removing the A2091 would'nt make any difference. In hindsight, I probably should have removed it..
Of the other people here who are having TF536 and A2000 problems, do you have any cards plugged into the Zorro slots??
Re: TF536 on A2000
Posted: 16 Jul 2020 02:53
by ericgla
I had all cards removed during my tests...
Re: TF536 on A2000
Posted: 16 Jul 2020 06:30
by 8 Bit Dreams
Maybe it's worth to recompile rev.1 FW we used to rev.2 pcbs and check does it work on A2k or not...🤔
Re: TF536 on A2000
Posted: 16 Jul 2020 15:06
by terriblefire
Just flash the working rev1 firmware in the rev2. IDE will not work everything else is unchanged.
Re: TF536 on A2000
Posted: 16 Jul 2020 15:28
by Maximilian
The A2000 has a lot of resistor packs near the 68000 socket, could it be a termination issue due to the pull ups on A24-A31?
Re: TF536 on A2000
Posted: 16 Jul 2020 15:52
by terriblefire
Maximilian wrote: 16 Jul 2020 15:28
A24-A31 are entirely internal to the TF536.. so its not likely. Its more likely an issue with the clock phase control.
Re: TF536 on A2000
Posted: 17 Jul 2020 00:20
by ericgla
I flashed my board back to the rev1 firmware.
Same behavior as before with the 3.1 rom, flashing bars followed by a black screen.
DiagROM 1.2 doesn't get as far as before, hanging during the fastmem check. I did try to plug in a mouse to to cancel fastmem detection, but with a mouse connected DiagROM only sends <> to the serial port, and hangs showing a blue screen.
Re: TF536 on A2000
Posted: 17 Jul 2020 00:45
by ericgla
I forgot to mention in my previous post that I have a 24 MHz 8 channel logic analyzer (a cheapo china one) on my bench, and would be happy to do any signal captures on my rev6 board that might help identify the issue...
Re: TF536 on A2000
Posted: 17 Jul 2020 09:48
by GadgetUK164
Is it possible the SMD component sizes fitted by the PCB manufacturer are the wrong size or something (on the underside). eg. resistor arrays, resistors.
