Page 5 of 68
Re: Icky - Progress
Posted: 19 Sep 2018 21:08
by Icky
terriblefire wrote: 19 Sep 2018 20:54 How are things going.. do we have a current list of required patches? Is there anything I can add to DiagROM to help out?
I've not had a chance to start my build yet.. but i have been clearing the decks so i can start. Is it worth it with this revision?
Hi Terriblefire.
Exxos has a list of patches here https://www.exxosforum.co.uk/forum/viewt ... =19&t=1185
I think from my perspective its been the video thats my problem. As Exxos mentions I need to get that sorted so I can actually see where I am.
I have only been reading the DiagROM thread briefly. I guess from my experience here it would be good to see each step in the start up where the board gets to and where it is halting or reseting.
Re: Icky - Progress
Posted: 19 Sep 2018 21:18
by terriblefire
Icky wrote: 19 Sep 2018 21:08 Exxos has a list of patches here https://www.exxosforum.co.uk/forum/viewt ... =19&t=1185
Perfect.
DiagROM should do that for you. I am actually happy to build a specific fork for this STF Remake. I did this when I make my CD32 accelerator and it cut the time to figure out issues by years. The early startup tests do not need ram.. they use registers for function return calls. So it can diagnose early problems.
A sample of what they do ..
[ @���U
Garbage before this text was binary numbers: 1, 2, 4, 8, 16, 32, 64, 128, 240, 15, 170 and 85
To help you find biterrors to the mfp. Now starting normal startuptext etc
Atari DiagROM V0.9 - 16-Sep-18
 - By Stephen J. Leary
 - Based on the Amiga Version By John (Chucky/The Gang) Hertell
- Parallel Code $ff - Start of ROM, CPU Seems somewhat alive
 - Resetting all hardware (RESET instruction):   Done.
 - Reinitialising Video ($10000): Done.
 - Sending reset to keyboard controller (IKBD Reset): Done.
- Parallel Code $fe - Test UDS/LDS line
 - Test of writing word $FFFF to $400 OK.
 - Test of writing word $00FF to $400 OK.
 - Test of writing word $FF00 to $400 OK.
 - Test of writing word $0000 to $400 OK.
 - Test of writing byte (even) $ff to $400 OK.
 - Test of writing byte (odd) $ff to $401 OK.
- Parallel Code $fd - Start of chipmemdetection
  - Performing MMU Configuration: $08 Done.
Addr $00080400   OK  Number of 32K blocks found: $10
Startaddr: $00000400 Endaddr: $00080000
- Parallel Code $fb - Memorydetection done
- Parallel Code $fc - Start of motherboard fastmemdetection
Detecting if we have a working raster: DETECTED
Detected Chipmem: 512KB
If there is a useful thing i can make it do and then report on serial port let me know. Happy to add.
Re: Icky - Progress
Posted: 19 Sep 2018 21:23
by Icky
terriblefire wrote: 19 Sep 2018 21:18 DiagROM should do that for you. I am actually happy to build a specific fork for this STF Remake. I did this when I make my CD32 accelerator and it cut the time to figure out issues by years. The early startup tests do not need ram.. they use registers for function return calls. So it can diagnose early problems.
Oooh that looks interesting. I must read more. I think the serial port hasn't been tested yet on the board as its new circuitry so I think we need to get that up and working to see if this can help with the board.
Re: Icky - Progress
Posted: 19 Sep 2018 22:03
by Icky
exxos wrote: 18 Sep 2018 23:21
Icky wrote: 18 Sep 2018 23:18 OK - I found some bad soldering on the RP6. I cleaned it up and now I am getting bombs but the screen is still all over the place. Let me attach a video
OK.. might be idea to measure resistance on each CPU pin and make sure you read something to VCC.. (IE 2.2K)
Just measured and all the pins have the correct pull-up resistance as per the RP's they are connected to.
Re: Icky - Progress
Posted: 19 Sep 2018 22:05
Icky wrote: 19 Sep 2018 22:03 Just measured and all the pins have the correct pull-up resistance as per the RP's they are connected to.
Should be ok now then... I checked a heck of a lot of stuff on the schematics last night and couldn't find anything wrong anywhere now.. not saying my checking is good, but once we get your video stable.. we should be able to make a better leap forward...
Re: Icky - Progress
Posted: 19 Sep 2018 22:30
by Icky
exxos wrote: 19 Sep 2018 22:05 Should be ok now then... I checked a heck of a lot of stuff on the schematics last night and couldn't find anything wrong anywhere now.. not saying my checking is good, but once we get your video stable.. we should be able to make a better leap forward...
Yes it was an epic adventure yesterday.
I'm going to try and get some images of the waveforms from HSYNC, VSYNC etc on the STF and then if I can get round to it some off of my original STM as well.
If I leave the STF running I do see it keep cycling (rebooting) every 1-2 minutes.
Re: Icky - Progress
Posted: 19 Sep 2018 22:34
Icky wrote: 19 Sep 2018 22:30 I'm going to try and get some images of the waveforms from HSYNC, VSYNC etc on the STF and then if I can get round to it some off of my original STM as well.
If we can compare against a working machine, then it will help us diagnose things. If we can get your video stable, you could probably try diagrom, and see if something fails to setup..
My "bag of bits" arrived at the assembly place today, they suggest I may get it back sometime next week.. so I can join in the fun then as well :)
Re: Icky - Progress
Posted: 19 Sep 2018 22:40
by PhilC
exxos wrote: 19 Sep 2018 22:34 My "bag of bits" arrived at the assembly place today, they suggest I may get it back sometime next week.. so I can join in the fun then as well :)
Cool, looking forward to you getting yours. I may crack open my Mega so that I've got something to copy as well.
Re: Icky - Progress
Posted: 19 Sep 2018 22:52
by Icky
exxos wrote: 19 Sep 2018 09:09 Also check V&H sync voltages and waveforms, and also check CSYNC voltages vs a working ST...
So this is weird - since I have been getting the bombs after finding the RP6 not being soldered correctly looking at the waveforms on STF Remake board its like it thinks its in High res mode with these frequencies.
HSYNC = 35.8kHz
VSYNC = 49.7Hz then 71.2Hz
When the board first boots and I have white screen and see bombs
When its in the black wavy picture out of sync after bombs
Re: Icky - Progress
Posted: 20 Sep 2018 00:12
by Icky
Just for kicks i plugged in a high res adaptor into the board and measured the HSYNC
HSYNC = 15.6kHz
Its like the hi-res select line is selecting the frequencies the wrong way round. i.e. with scart cable in its setting the board to hi-res frequencies and when plugging in a hi-res vga cable its setting the board to low-res frequencies
