Page 40 of 57
Re: A5000 - diving in at the deep end!
Posted: 05 Dec 2023 00:30
by HigashiJun
8-)
Posted: 05 Dec 2023 09:02
OK, so things are moving forwards :)
The A5000 can see the NFS mount on my Windows server:
But there is a problem with the NFS client, since it consumes a ton of memory and with only 4MB to play with, the max for an A5000, it's a problem:
Though I may be able to boot in a minimal config if I need to free memory for the purposes of file copying.
Moonfish on the other hand is an NFS server and consumes just 64KB and exports an NFS folder my Mac can see:
So that will be my next port of call I think, seeing if I can mount the NFS share on my A5000 to another machine.
I like progress.
Posted: 05 Dec 2023 09:35
by HigashiJun
You're not the only one...
:lol:
Posted: 05 Dec 2023 10:09
by stephen_usher
:dualthumbup:
Posted: 05 Dec 2023 10:37
Aaaand SUCCESS!!!!!
Here you can see 3x NFS3 shares on my Windows 2016 server named 'Hyper1':
You can also see I am connected to the one called A5000 :)
The settings on the Windows NFS share are as follows:
And permissions are set to read/write.
The result is I can simply supply a UID and a GID and connect as an unmapped user. I can read/write to the NFS shares and copy files from them. This is a very happy day for me :)
Posted: 05 Dec 2023 10:56
by stephen_usher
Yay!
Posted: 05 Dec 2023 10:59
by alexh
I imagine that your SAMBA issues are something similar
Posted: 05 Dec 2023 11:00
by HigashiJun
:girldance: :yay2: :girldance: :yay2: :girldance:
Posted: 05 Dec 2023 11:08
alexh wrote: 05 Dec 2023 10:59
Well the Samba server for RiscOS needs 8MB apparently, so not happening on my A5000. As for LanMan98, there is something more fundamental failing as the initial TCP setup isn't working, so it never gets to try authentication.
I can live without finding out what the cause is as without any way of doing packet capture on the A5000 I can't see what it's doing internally, and I know the SYN.ACK packet is getting as far as the machine having tapped it.
NFS is a bit of a double edged sword, as Sunfish is a real memory hog, so I have to boot clean to do any file moving operations, but I'll take it.
It proves that networking is working, and I can now transfer files directly across the network.
Posted: 05 Dec 2023 12:57
by alexh
Glad you've got something that works.
rubber_jonnie wrote: 05 Dec 2023 11:08
You said this before and I said you don't need a Samba server you need a Samba client.
Might be worth trying the integrated RiscOS "Omniclient + LanManFS" ? If you wanted to? :-)
