Page 39 of 299
Re: General Stuff(tm)
Posted: 02 Feb 2022 10:15
stephen_usher wrote: 02 Feb 2022 10:05
The replacement PSU has arrived. It'll need some thought about how to secure it as, of course, the mounting holes won't line up with the originals. Also, I hope that the 'scope doesn't actually try to draw the full 20A@12V as I could only find a 16.7A supply in the right sort of form factor.
The original PSU board does look rather scorched, I take it that it's beyond repair?
I take it is CRT, so you might be right about it needing more than the 16.7A PSU you have. Could you test it with a bench supply or supplies, see if it'll give you an idea of the current draw?
Posted: 02 Feb 2022 10:25
by stephen_usher
Well, potentially it's fixable, if I knew what the values of the two toasted SMD resistors were next to the chip. There are a couple of fine traces on the main board which would need bodge wires too.
It's not a CRT, it's an LCD display with cold cathode backlight, so I don't know why it would be so power hungry. Hopefully 200W rather than 240W will be good enough.
I tried with my 5A bench PSU and that started to boot at that current but the limiter tripped.
It's a nice 4 channel, 50MHz 'scope with 16 channel logic analyser:
- tektronix-mso5054.jpg (42.7 KiB) Viewed 2215 times
Posted: 02 Feb 2022 10:39
stephen_usher wrote: 02 Feb 2022 10:25
Is there a schematic you could get the resistances from? Sounds all rather positive though, should be a pretty useful tool when you've got it running, having the integrated LA is nice.
Posted: 02 Feb 2022 10:42
by stephen_usher
No schematic, but there is a service manual, which is how I got the voltage and rating.
Posted: 02 Feb 2022 10:56
stephen_usher wrote: 02 Feb 2022 10:42
I do hate it when there's no schematic!!
Posted: 02 Feb 2022 19:44
by stephen_usher
It's alive!
First tested with the PSU outside the main system to make sure everything was fine and I adjusted the voltage.
- IMG_2558.jpg (64.36 KiB) Viewed 2192 times
It took a bit of persuasion (with a hammer) but I finally got it inside and all back together and working.
- IMG_2560.jpg (75.73 KiB) Viewed 2192 times
Posted: 02 Feb 2022 22:18
by stephen_usher
Oh! This scope can do bus timings form the main channels and protocol decode too.
Big league stuff.
Posted: 02 Feb 2022 22:19
by JezC
@stephen_usher Sounds like your luck was in with that one!
Posted: 02 Feb 2022 22:44
by stephen_usher
Yeah. I think this must have been close to the top of the range maybe?
Posted: 02 Feb 2022 22:52
by stephen_usher
It's now passed its internal calibration tests and self diagnostics. Woot!
The "info" menu shows that it doesn't have any module licenses installed. I'm not surprised as there aren't any modules supplied with it.
