Page 37 of 48
Re: BLITTER RE-CREATION THOUGHTS
Posted: 10 Dec 2021 20:38
by mmx01
More I look at the timings, more I think PLL should be clocked from external crystal and CLK as signal synced to Atari. This would sync bus events but not impede logic operations. Perhaps that's a dead ally but first impression is that processing is consuming too many cycles. Or fiddle with P_CYCLE_CNT: process.
Posted: 11 Dec 2021 20:03
by mmx01
Tried to get blitter on 16Mhz clock from MMU pin 5 but it did get messy, division of clock counts in fpga code did not seem to improve anything. I wish I had designed some pads around clock source configuration but yeah...
Thanks to great input from @Icky and a lot of hacking hours not fully understanding ports, port maps and how to pass different signals in vhdl finally some progress! This code provided other insights how to further tune fpga blitter:
https://github.com/gyurco/MiSTery/commi ... 6f252776f7
Still not good though, lines no longer spread over time but top part is distorted. Playing with 32Mhz vs. 64Mhz clocks is not delivering further benefits.
Stock code - blitting score in mid-res: time 5.965
New code - blitting score in mid-res: time 6.600
Hmm. not going in the right direction but at least new code is working and not freezing the machine like it did for 2 days ;) Next seems to be waitstates, T_SLICE and CYCLE_CNT. T_SLICE I am feeding 8Mhz and overall clock is 32Mhz I will try to rewrite with raising edge & falling edge. CYCLE_CNT for HOG is 80/40.
Posted: 15 Oct 2022 13:53
by Icky
Thought I would do the final spin of the Phoenix Sparkalaphobia board now that the dev boards are functioning and its down to the firmware tweaks to complete.
This board is designed to fit directly into a PLCC68 socket as a drop in replacement of an original BLITTER chip.
Of course the most limiting factor now is the FPGA chip shortage.
Screenshot 2022-10-15 at 13.46.00.png (980.59 KiB) Viewed 1977 times
Screenshot 2022-10-15 at 13.47.02.png (452.24 KiB) Viewed 1977 times
Screenshot 2022-10-15 at 13.42.12.png (837.72 KiB) Viewed 1977 times
Posted: 15 Oct 2022 14:03
by Badwolf
Icky wrote: 15 Oct 2022 13:53 This board is designed to fit directly into a PLCC68 socket as a drop in replacement of an original BLITTER chip.
Looking good. What chips are you using for the level shifting there, BTW?
Posted: 15 Oct 2022 14:17
by Icky
Badwolf wrote: 15 Oct 2022 14:03
GTL2010PW - https://www.ti.com/lit/ds/symlink/sn74gtl2010.pdf
@exxos had done various testing of translators and we have found these to be best suited to our needs. Its also the same ones we use on the H5 boards to provide the 3V3 bus. I cant seem to find the thread on @exxos' experiments.
Posted: 15 Oct 2022 14:30
by Badwolf
Icky wrote: 15 Oct 2022 14:17 GTL2010PW - https://www.ti.com/lit/ds/symlink/sn74gtl2010.pdf
Cheers, will have a look at those. My normal ones are only 8 bits wide and are occasionally unobtanium.
Posted: 15 Oct 2022 14:38
Icky wrote: 15 Oct 2022 14:17 @exxos had done various testing of translators and we have found these to be best suited to our needs. Its also the same ones we use on the H5 boards to provide the 3V3 bus. I cant seem to find the thread on @exxos' experiments.
Its all at the start of this thread. Experiments are scattered over several pages.
https://www.exxosforum.co.uk/forum/view ... t=60#p9808
The GTL chips were the only ones I could get to work right. Even Texas versions of the same chip were screwy IIRC.
Posted: 15 Oct 2022 16:31
by Tbs123456
Is it a 100% blitter replacement?
Where did the name sparkalaphobia(pronounced spark-ala-phobia?) Come from?
Posted: 15 Oct 2022 16:57
Tbs123456 wrote: 15 Oct 2022 16:31 Is it a 100% blitter replacement?
Yes. Its a project to offer a alternative to the impossible to find Blitter chips.
Tbs123456 wrote: 15 Oct 2022 16:31 Where did the name sparkalaphobia(pronounced spark-ala-phobia?) Come from?
Sparkalaphobia - The fear of Glitter.. Glitter as autocorrect keeps changing Blitter to Glitter :lol: :roll:
Posted: 15 Oct 2022 20:51
by Cyprian
how to buy that glitter
my ST is waiting for it
