Page 36 of 38
Posted: 20 Jul 2023 12:58
I know!!!
I think I'll use an ST joystick extender so I can push the machine a little further back though.
Posted: 26 Jul 2023 15:55
Just to show off the v2 Analog a bit, it is possible to change the base screen colours via the config utility, which is nice if you want a little green screen nostalgia:
- PXL_20230726_144928612.jpg (255.95 KiB) Viewed 8296 times
Which is nice as it's what we had at school before the BBCs arrived. Normally monochrome means just that and colour was determined by the display.
Or you can go for a bit of a C64 palette:
- PXL_20230726_103653860.jpg (238.43 KiB) Viewed 8296 times
It's also possible to customise the fonts as well, though I have yet to try this.
Posted: 04 Aug 2023 22:32
by Tomswork
Another adaptations the vga analog board in through hole
Tom
https://github.com/Retrotink/Apple-II-VGA?search=1
@rubber_jonnie
Posted: 04 Aug 2023 22:38
Very good to know. I believe the v2 Analog was based on this.
Posted: 05 Jan 2024 14:07
And so the Apple IIe now has serial and parallel adapters:
- PXL_20240105_140024330.jpg (398.78 KiB) Viewed 8039 times
- PXL_20240105_140235065.jpg (301.1 KiB) Viewed 8039 times
All I need to do now is build a parallel port cable I can fit on the pack panel, as it didn't come with one, unlike the serial card, though to be fair it was a fair bit cheaper.
Looking quite full in there, the only thing I might consider is to replace the FDD card with something that can do 'a bit more' like a Liron card.
Posted: 06 Jan 2024 09:44
by HigashiJun
rubber_jonnie wrote: 05 Jan 2024 14:07
Really looking good !
Such an old machine with so much expansions, all packed internally.
Love it !
8-)
Posted: 06 Jan 2024 10:32
HigashiJun wrote: 06 Jan 2024 09:44
Love it !
8-)
Yeah, it is such a great design, and all I need now is the parallel cable to fit to the back and the ports are done. I have a dot matrix printer I'm going to try with it once that's done, and I'm looking for a piece of terminal software and I'll try using it with an ST diag cart :)
If I can find one at a good price I may swap out the homebrew floppy controller for a Liron to work better with my FloppyEmu.
Posted: 06 Jan 2024 11:39
by HigashiJun
Have you considered a Yellowstone card instead of the Liron ?
I don't know if they still have some, but it's worth trying;
https://www.bigmessowires.com/yellowstone/
Posted: 06 Jan 2024 12:49
Actually, it's certainly something I will consider, BMOW have some decent products, and while Liron cards appear to be a lot cheaper, the Yellowstone is a lot more flexible.
Posted: 22 Jan 2024 12:05
Well the the LS93 for the OSI didn't, but a parallel port did :)
So I'm in a position to build the parallel cable for the Apple II now :)
- PXL_20240122_114545332.jpg (322.68 KiB) Viewed 1545 times
I bought this little doohickey as an experiment, it was something like £13 from Amazon:
- PXL_20240122_115648337.jpg (220.43 KiB) Viewed 1545 times
And TBH it's pleasantly surprised me.
It works great and for small fiddly jobs and quick jobs, it's easier to manoeuvre around without a cable dragging around and heats up very quickly. I certainly wouldn't use it for any large jobs, but for a quick handsfree soldering job it's surprisingly good.
Will see how it goes using it to build the parallel cable and I'll report back later.
