Page 36 of 51
Re: TF1230 Beta Interest (Open Source)
Posted: 18 Sep 2021 15:03
by arkadiusz.makarenko
terriblefire wrote: 18 Sep 2021 11:39
Alpha for the 288 CPLDs....
tf1230r1_main_top_288.zip
EDIT: Since i dont actually have a 1230 with a 288 CPLD its untested.
Is there a difference between 144 and 288 version except cell size?
Posted: 18 Sep 2021 15:09
by go0se
arkadiusz.makarenko wrote: 18 Sep 2021 15:03
Price.
Posted: 18 Sep 2021 15:25
by markus0321
markus0321 wrote: 18 Sep 2021 13:58
markus0321 wrote: 18 Sep 2021 13:10
Wow! I already have the entire TF1230 soldered, I'm programming the CPLD right away and I'm starting to run it and test it.
Thanks a lot for the quick help. You are great
Not working...
There is only a black screen on the diag-rom. I checked the soldering under a microscope and it looks good. My A1200 is rev 2b will try to do timingfix, if it doesn't help, I will check it on version 1.d4 1.d1 .....
I changed the CPLD to another 288 chip and it works with the diag-rom! :-)
but does not detect FAST 0kB memory :-(
Posted: 18 Sep 2021 15:37
by terriblefire
you've done complete memory detection? Menu 2 option 6 i think?
Posted: 18 Sep 2021 15:47
by markus0321
terriblefire wrote: 18 Sep 2021 15:37
In Workbench it shows 64MB Fast nicely.
I suspected the xilinx chip because it was damaged more than once when I bought it on aliexpress. Just unnecessary stress. But in the end it is great because if it were not for this chip, the card would start immediately.
BusSpeed CHIP 6.2 / 7.0 MB / s R / W Wow! FAST 25.7 / 35.5 super
SysInfo Mips 9.63 HDD: 2 058 722 on the internal controller (I do not have goldpins to check the one on the card)
Workbench 3.2 with kickstart 3.1
Thank you again and I'm going to do further tests :-)
Posted: 18 Sep 2021 15:51
by PaulJ_2.0
I just soldered in a 288 and flashed it.
Revision 2B working so far
128MB RAM installed and seemingly fine too.
More testing now.
Posted: 18 Sep 2021 15:53
by markus0321
Complete memorydetection detects 4 areas of 64MB together shows 256MB later
In fact, I have soldered the same memories as in TF536, i.e. 64MB
This is correct behavior?
Posted: 18 Sep 2021 15:55
by terriblefire
markus0321 wrote: 18 Sep 2021 15:53
Yes thats correct.
Posted: 18 Sep 2021 16:14
by markus0321
terriblefire wrote: 18 Sep 2021 15:55
Yes thats correct.
So 288 also works ok but it's a nice option for someone who already has it or can't find 144. I will check if it works with my second Amiga version 1D.1
Posted: 18 Sep 2021 16:24
by terriblefire
If goose can send me a 288 version (or even a blank) the faster ata from the TF1260 will fit in the 288. The 144 is utterly full.
