The only time it boots is when I disable the cache on the board.. but its not very stable.
Re: REV 3 - The beginning
Posted: 29 Apr 2021 23:18
Tried EMUTOS on the STE and that goes into a reset loop after the splash screen. TOS206 always starts resetting just as it gets to desktop. Though its odd it can load stuff off floppy like in the video.
I've played around and no idea what's up with it all. The only possible clue is the diagnostic cartridge says I8 exception error, whatever that means.
Posted: 30 Apr 2021 12:35
by Badwolf
exxos wrote: 29 Apr 2021 23:18
I can't find any reference to I8 in the STE, or (ST or Falcon, since I was checking) service manual. Maybe a later introduction?
How are you connecting this? Is the onboard CPU removed?
Posted: 30 Apr 2021 12:45
Badwolf wrote: 30 Apr 2021 12:35
I looked through the whole lot, I could not find it either.
TF536 is on a DIP to PLCC adapter, plugged into the STE CPU socket.
oops..
Still none the wiser :lol: :roll:
Posted: 30 Apr 2021 14:46
by Badwolf
Ohhhh, E8.
Why didn't you say? ;)
exxos wrote: 30 Apr 2021 12:45
Ditto! :lol:
This is where EmuTOS could be more use again, though. You say it can boot from floppy? We could do you an EmuTOS PRG version with debugging turned on in various modules. If nothing prints on screen (or it vanishes into reset before you can read it), it could be rebuilt to spit out over serial.
ROM even better as then the PC can be directly interpreted, but unless you've any PLCC44 EPROMs, that's not really an option.
Posted: 30 Apr 2021 14:51
Badwolf wrote: 30 Apr 2021 14:46
This is where EmuTOS could be more use again, though. You say it can boot from floppy? We could do you an EmuTOS PRG version with debugging..
EMUTOS running from ROM resets just the same... but TOS206 and ET run fine on my H4..
I might be able to run ET from the AUTO FOLDER on the floppy.. that seems to work, just can't get to desktop.
Posted: 30 Apr 2021 15:18
I think Roger sent me a debug version of EMUTOS yesterday, though I cannot seem to start from the auto folder has just keeps resetting the again :(
Posted: 30 Apr 2021 15:23
by Badwolf
exxos wrote: 30 Apr 2021 15:18
We'd need to guess which module to put the debugging output in.
In your ROM version, you said you can see the splash screen. If you hit escape there (to go to the CLI) does it reboot before you get the user prompt?
Posted: 30 Apr 2021 15:30
ah... :lol:
Go find some more ram and then try running from auto again...
Posted: 30 Apr 2021 15:31
Badwolf wrote: 30 Apr 2021 15:23
It pretty much resets after drawing the splash screen.. I don't think I will have chance unless I frantically press escape whole time... Give it a try anyway...
