Page 333 of 339
Posted: 09 Apr 2026 23:20
So something died on my H5 :(
:sigh:
With the RAM in the diag-cart shows RAM fault..
- Capture.PNG (31.95 KiB) Viewed 1118 times
If I plug the RAM in, I just get 1 odd square appear on the terminal and garbage on the screen ?!
- IMG_4993.JPG (83.51 KiB) Viewed 1118 times
I swapped out the RAM, GLUE,MMU, CPU, poked around everywhere.. Just died out of the blue..
Anyone seen that kinda fault before ?
Posted: 10 Apr 2026 08:53
by PhilC
@exxos ram buffer chip?
Posted: 10 Apr 2026 10:56
PhilC wrote: 10 Apr 2026 08:53
Would it still spew out diagnostic information if the buffers were bad though..
I plugged in my little diagnostic board, it shows the correct binary sequence for the start of ROM. So it's not like the address or databus is completely trashed. It runs code from ROM , the diagnostic cartridge, but only when the simm is unplugged. I mean really the diagnostic cartridge shouldn't care if the RAM is bad :roll:
I just continuity checked the simm back to the MMU.. its fine . I did try a Falcon RAM card.. Same problems.. The last thing I did was solder a wire onto the ROM2 line. If the LS11 hd gone bad.. it would have still booted with a ST536 anyway.
I will have to try and find diagrom ST version somewhere and give that a go.
Posted: 10 Apr 2026 11:20
I'm not sure this helps either, thats just locked up at that point.
- Capture.PNG (31.1 KiB) Viewed 1080 times
I'm using this one..
https://github.com/terriblefire/diagrom ... gROMST.rom
104 space, and plugged into the H5 ROM socket.
Posted: 10 Apr 2026 18:40
Finally had a chance to have a look at this problem some more...
Got to address lines measuring 1.1K to Vcc which is wrong. The measuring between the two address lines there is a dead short ! The question is where.....
- IMG_4994.JPG (369.21 KiB) Viewed 1067 times
- IMG_4995.JPG (305.69 KiB) Viewed 1067 times
I guess there is two options..
1) put my power supply across the two pins and see what start smoking..
2) go find my low resistance meter...
Posted: 10 Apr 2026 19:54
So option 1 it is..
Started with a gentle 10mA.
- IMG_4996.JPG (344.96 KiB) Viewed 1056 times
Then 50mA.
- IMG_4999.JPG (349.23 KiB) Viewed 1056 times
Then 300mA.
- IMG_5002.JPG (262.44 KiB) Viewed 1056 times
Nothing got hot or smoked. Granted wattage not that high. But that's a pretty substantial short somewhere !
Time to bring out the low resistance meter then :roll:
So first of all testing across basically the middle area of those to address lines...
- IMG_5006.JPG (314.36 KiB) Viewed 1056 times
Then measuring on the SMT GLUE pad.. Getting closer...
- IMG_5007.JPG (255.27 KiB) Viewed 1056 times
Then measuring to the cartridge port.. Getting closer still...
- IMG_5008.JPG (183.94 KiB) Viewed 1056 times
Cartridge port to the SMT GLUE pad.. Getting closer...
- IMG_5009.JPG (317.41 KiB) Viewed 1056 times
Cartridge port to SMT MMU pad.. Getting closer...
- IMG_5010.JPG (331.1 KiB) Viewed 1056 times
Cartridge port to the PLCC MMU.. Homing in....
- IMG_5011.JPG (341.33 KiB) Viewed 1056 times
Practically right on top of it... !
- IMG_5012.JPG (295 KiB) Viewed 1056 times
So looking around the ROM socket...
- IMG_5013.JPG (402.92 KiB) Viewed 1056 times
:headbang:
#BobsLaw.
Now things are starting to happen ! :D
- IMG_5014.JPG (198.62 KiB) Viewed 1056 times
Posted: 11 Apr 2026 02:54
by ijor
exxos wrote: 10 Apr 2026 19:54
So option 1 it is..
See, I could never do that kind of hardware investigation, not even with the help of the most powerful AI in the world. At least not unless the AI can also control a robot to perform the actual physical work, not just give recommendations. :)
Posted: 11 Apr 2026 12:28
ijor wrote: 11 Apr 2026 02:54
Physical work like that its hard for me sometimes because of my RSI. My hands always been a bit shakey which doesn't help. I'm losing finer control in my hands which isn't good. Need to rest more.. Always so much to get done though which is the problem.
Will try and keep off the forum for the next few days. I've got some smaller projects I'm working on which I think are cool.
Posted: 14 Apr 2026 23:23
New toys :D
- IMG_5028.JPG (70.66 KiB) Viewed 993 times
Posted: 15 Apr 2026 10:01
by Badwolf
exxos wrote: 14 Apr 2026 23:23
New toys :D
Ooo!
