Re: The Future of Our Community and Its Funding
Posted: 06 Sep 2024 16:05
This has taken me all day to do :roll: Mostly because mediawiki wouldn't let me edit common.css.. then another page I had css in didn't work. So started over with a clean css file and then MW decides to change my page code by adding <pre> tags which totally screwed up the formatting of the page ?! Just WHY does it need to change stuff on its own... :pullhair: :headbang:
Anyway...
https://atari-wiki.com/index.php?ti ... iki:Donate
This is now displayed at the bottom of the page...
It is scripted and will update automatically on donations (hopefully!) The cost per year for the calculation hasn't yet been accurately worked out, but its not going to be far off as its set now I think anyway.
I may have to do something about the user list for donations because the list will get extremely long with subscriptions every month.. :shrug:
the only idea is to list uses once and then have a field next to their name just simply quoting how many times they made a donation and when the last donation was...
Updated user list to correlate names. This will only work properly people use the same name and really should use their forum name in future..
EDIT2:
I will have to contact Stripe about the subscriptions because while payments will likely go through, I'm not sure about the "name to credit" will be passed automatically... If that's the case, I am not sure it's going to be possible to keep tabs on subscription payments :(
EDIT3:
The 2024 current expenditure has now been properly calculated :shock: it was higher than I thought at £707. :shock: the only real option currently to reduce costs is to reduce the full disk backups to once a month instead of once a week.. Not really good with the amount of updates which happen each week. There are daily backups copied over to a offsite server, but those are just the basics like SQL and HTML folders, they don't include the full system backups. But I guess if we struggle to hit the target, I may have to reduce costs and go down that road.
Anyway...
EDIT2:
EDIT3:
