Page 4 of 4
Re: DSTB1: testers for rev 2 firmware (requires modding a rev 1)
Posted: 13 Aug 2025 09:44
by Badwolf
Oldskool wrote: 12 Aug 2025 21:49
No it can’t run with a faster clock already tested it with a hbs640 with just the clock at 28 cache off.
So will just safe it for another project and keep the dstb1 in the old stf….
Fist thought it was a dstb1 thingie but it is not…
Well, it probably is -- as explained by the clock business. But, you know, compromises. :(
EDIT: unless it's a register conflict, of course. I don't know if they're documented for Lightning.
Posted: 14 Aug 2025 16:01
by Oldskool
Found another issue with the blitter.
If activated in menu the system will crash @ 16 mhz.
At 8 mhz it’s ok.
- IMG_3412.jpeg (159.83 KiB) Viewed 2226 times
Posted: 14 Aug 2025 17:02
by Badwolf
Oldskool wrote: 14 Aug 2025 16:01
At 8 mhz it’s ok.
Hmm. I spent a long time chasing getting the blitter to work & it was for me last time I tested.
If blitter is misbehaving for you, that probably goes some way to explaining your previous problems with ACSI devices (both are DMA).
Sadly I don't have the time to really work on this ATM.
Posted: 14 Aug 2025 17:18
by Oldskool
Should I try another firmware version ?
Posted: 15 Aug 2025 14:14
by Badwolf
Oldskool wrote: 14 Aug 2025 17:18
I'd only use the latest if I were you. I built you some debug builds but I can't remember what each of them did differently now, so I doubt it would help anyway.
Unfortunately this seems to be a bus arbitration issue that you keep running into and I can't replicate even if I could spare the time at the moment.
The project is, of course, open source so the absolute best thing would be if you could try building and flashing firmware yourself. Then you can experiment in situ and if we find a solution, publish it.
I still have to get around to finishing the rev2 design incorporating the fixes we've made using the bodge wires too.
Posted: 15 Aug 2025 19:36
by Oldskool
Not sure how to program a cpld. I’m just a “tester for rev 2 firmware”.
Posted: 15 Aug 2025 22:00
by Badwolf
Oldskool wrote: 15 Aug 2025 19:36
Yeah, no problem. And thank you for doing that! I don't have the same set up on my bench as I did when I was working on this one year ago, I'm afraid.
Currently I'm working on a Falcon motherboard in the shed and have a more complicated STFM project on my desk.
