With STE TOS206 ST536 TOS it does show up the STram test. But it does not see the TTram :(
I think it keeps on turning on 24 bit addressing by itself which is probably why :roll:
If I changed the header to 209 it just freezes then :(
Re: TOS RAM test routine ?
Posted: 05 Dec 2022 22:00
by stephen_usher
Use my fixcrc program to fix that. :-)
Posted: 05 Dec 2022 22:03
stephen_usher wrote: 05 Dec 2022 22:00
Never thought of that...
Though generally TOS doesn't lock up completely after failing the CRC test.. Unless something else funky is going on
Saying that it won't help.. As soon as Hatari sees "2.xx" it switches on 24bit addressing :(
I think someone mentioned this could be disabled in Hatari last time I was messing with it all.. with the usual "if you compile it yourself" type of "help" :roll:
Posted: 05 Dec 2022 22:19
by Badwolf
My fairly heavily modded Hatari oddly prints the dashes without reverse text then bombs at the start of the TT-RAM test.
With memvalid it just bombs early doors.
No bus error logged in the console, which is odd.
Screenshot 2022-12-05 at 22.17.57.png (75.51 KiB) Viewed 1559 times
Posted: 05 Dec 2022 22:25
Badwolf wrote: 05 Dec 2022 22:19
So you know how to do mods to Hatari then ? If that's the case if I could find line of code which has mentioned you could probably just remove that for me ? I would assume if it stopped switching to 24bit addressing then it would allow TTram to work ...
Posted: 05 Dec 2022 22:31
by Badwolf
exxos wrote: 05 Dec 2022 22:25
argh, how many seconds did it take you to do that ? :lol: GIMMIE!!! :chairsmack:
I only just found the email about it :lol:
Have a look at tos.c :
/* 32-bit addressing is supported only by CPU >= 68020, TOS v3, TOS v4 and EmuTOS */
if (ConfigureParams.System.nCpuLevel < 2 || (TosVersion < 0x0300 && !bIsEmuTOS))
ConfigureParams.System.bAddressSpace24 = true;
M68000_CheckCpuSettings();
I think it should work if you change the 0x0300 into 0x0200.
Posted: 05 Dec 2022 22:55
by stephen_usher
You could just change the TOS header to read 3.06 instead. :-)
Posted: 05 Dec 2022 23:00
stephen_usher wrote: 05 Dec 2022 22:55
That's what I mentioned earlier.. It just goes to desktop without doing any RAM tests :shrug:
Posted: 05 Dec 2022 23:02
by Badwolf
exxos wrote: 05 Dec 2022 22:33
:lol:
I'd been hacking that file already for my own nefarious ends.
I'm afraid a debug Linux version is probably not much use to you.
That should work -- isn't that where we came in? :D
