Page 4 of 8
Re: MSX Inbound!!
Posted: 05 Feb 2022 23:08
I think we've all got some hidden treasures, glad you found this one 😁
Re: MSX Inbound!!
Posted: 07 Feb 2022 10:19
@mrbombermillzy
Did a quick joystick test in basic and it all works just fine :)
Doesn't seem to be analog though, despite the feel.
Thanks again :)
Re: MSX Inbound!!
Posted: 07 Feb 2022 10:23
by mrbombermillzy
rubber_jonnie wrote: 07 Feb 2022 10:19 @mrbombermillzy
:shock: Really? Man, that is loose then!
Reminded me of the gearbox in my old Fiat Panda 4x4! :lol:
I'm guessing it's meant to be like that then?!
Re: MSX Inbound!!
Posted: 07 Feb 2022 10:32
mrbombermillzy wrote: 07 Feb 2022 10:23
I'll pull it apart and check it out, but yeah, super soggy!!
Will get some pics.
Re: MSX Inbound!!
Posted: 07 Feb 2022 10:35
Colour me impressed, the Tosh has brass case screw inserts:
Lid is off as the 'S' key is a bit variable so I'll pull the switch for cleaning, everything else so far is very well built.
Re: MSX Inbound!!
Posted: 07 Feb 2022 10:44
And here is the very neat mainboard:
Re: MSX Inbound!!
Posted: 07 Feb 2022 10:55
by mrbombermillzy
Gosh!
How neat and orderly is that?!
Re: MSX Inbound!!
Posted: 07 Feb 2022 11:05
mrbombermillzy wrote: 07 Feb 2022 10:55 Gosh!
Clearly laid out by somebody with a penchant for things that are neat and orderly!!
Re: MSX Inbound!!
Posted: 07 Feb 2022 11:26
So, I found out the reason why the 'S' key was a bit erratic:
The light grey dome is from the MSX machine, and has a large tear, and won't go back into the housing. The dark grey dome is from my ST spares drawer, and was taken directly from a scrapper keyboard.
The ST dome fits perfectly in the switch housing, and after cleaning the contacts at the bottom of the housing, it works just fine!!
The feel is a bit firmer, and actually a bit nicer than the original MSX item (The ST dome isn't as thin, so a bit more resistive to force), but it works for me and a nice quick fix for the problem at hand.
Re: MSX Inbound!!
Posted: 07 Feb 2022 18:48
Minor repairs and a deep-ish clean of the Tosh keyboard and it's looking great!!
I have to say, the build quality is fantastic, and compared to some of the comparable machines of the era it feels kind of high end :)
Composite display is very nice, though not the best pic of it I've taken:
But the biggest surprise was the joystick, seen here disassembled for cleaning:
@mrbombermillzy it turns out that it is analog, but when reading the stick, all I get are values from the 8 corners and trigger.
Wondering if there is a way of reading the analog values?
Seems there is some minor damage to the handle, but kind of cosmetic and not enough that can't be fixed with a spot of glue, and certainly nothing that would stop it working.
Just needs a clean inside and out, probably a spot of contact cleaner on the pots and off we go.
I just need to get the bits to make a cassette cable and I should be able to get some games going on it.
Very impressed with this machine overall.
