Page 4 of 12
Re: Steve's H5 A3.14 Build (Chicken Pie edition)
Posted: 25 Dec 2020 11:05
by Steve
Just wanna say thank you to @PhilC for getting my H5 working. Combination of a bad MFP and a botched patch :)
Still got a little bit of troubleshooting to do in regards to the whites being a shade of yellow. Notice how it kind of 'smears' with different strengths of yellow. This makes me think it's something on the very end of the video output circuit causing it. Does anyone have any suggestions, I was thinking of desoldering/resoldering the DAC. But it's probably not the DAC.
Posted: 25 Dec 2020 11:19
by DoG
It seems that you got a missing or stuck bit on blue. Check Shifter (pin 21, 22, 23) or the multiplexer for blue (74AC157) then the DAC.
Posted: 25 Dec 2020 12:09
by Steve
@DoG
Thx for pointing me in the right directions, cheers & merry xmas :D
Posted: 25 Dec 2020 12:22
by PhilC
@Steve had to leave some.of the fun for you to sort out. Won't take you long.
Posted: 01 Jan 2021 15:18
by Steve
I had some time to try and fix my Gipsy Kiss colored screen today :lol:
* Every pin and trace on the multiplexers seems fine
* Re-soldered, re-socketed & ultrasonically cleaned the shifter
* Checked all shifter pins
* De-soldered & resoldered the DAC
~ Still got Gipsy Kiss yellow screen :?
Not sure what to do now to be honest. It's not my vga socket as it was the same at Phils.
I guess the shifter could be faulty? I'm wondering if anyone could lend me a spare shifter for testing, I'd cover the post.
Posted: 01 Jan 2021 15:21
by PhilC
@Steve Try wiggling the monitor socket, I found it very loose on my adaptor, might be you need a new socket?
Posted: 01 Jan 2021 15:26
Just get the diagnostic cartridge on colour test, and check all the bits are switching on the shifter outputs For starters...
Posted: 01 Jan 2021 15:28
by PhilC
exxos wrote: 01 Jan 2021 15:26 Just get the diagnostic cartridge on colour test, and check all the bits are switching on the shifter outputs For starters...
Seemed ok here with that when I tested it.
Posted: 01 Jan 2021 15:34
PhilC wrote: 01 Jan 2021 15:28 Seemed ok here with that when I tested it.
Tested the other side of the buffers as well ?
Posted: 01 Jan 2021 15:36
by PhilC
@exxos , no I hadn't, I was more interested in getting it to work.
