Re: Steinberg Avalon cartridge
Posted: 18 May 2020 18:55
So sorry again, the .o was not attached... I'm repacking this correctly
We welcome retro users & hardware gurus alike! Come and join the party :)
https://www.exxosforum.co.uk/forum/
Now that should be goodbeel1 wrote: 18 May 2020 15:19 The attached little software should gather enough data to make a virtual dongle that will pass initial Avalon dongle check, according to what does this version of Avalon: https://atarimusic.exxosforum.co.uk/forum/topic?f=23&t=807
Run it with the dongle connected, this will produce a ~1kB .txt log file. It may be a bit slow on a floppy, I haven't tested it on real hardware, and for my work on Synthworks I used M-Disk :D
EDIT: website is no longer live - see here instead viewforum.php?f=34
(The version of Avalon on Steinberg FTP crashes with 4 bombs BTW: ftp://ftp.steinberg.net/Archives/Atari/avalon/ :cussing: )
It would help if you could run the program beel1 posted with your Avalon key, and post the created txt file here. That way I can verify the method of making clones available to emulators.JezC wrote: 17 May 2020 10:14 This is all sounding very positive!
If it would help - I have Synthworks dongles for the Yamaha DX & Korg M1 (as well as Cubase 3 & Avalon) so I might be able to set them up with my synths & compare operation with & without a dongle?
It may take a period of time to get the results but happy to help where/when time allows.
Just a hickup, but irritating. It does give me some incentive to in addition to emulator support also try to produce either a working GAL16V8 replacement or, if the equations cannot be reversed from the data, some MCU based hw clone.beel1 wrote: 18 May 2020 22:38 Now you have a fried dongle, so at least they were right about the fact that they are not eternal, but still... I'm really sorry for you :(
Try running Avalon with the dongle first :DJezC wrote: 18 May 2020 22:37 @troed Ok - will try to do that tomorrow if I can.
Is it worth trying it with my two Steinberg Synthworks cartridges as well?
************************* Power On ************************
>>> Start Emulation <<<
FA0000 L 000000C0
FA0000 L 01115A0C
FA0000 L 0019AF30
FA0000 L 0003AF24
FA0000 L 00000F18
FA0000 L 000044D4
FA0000 L 0219665C
FB00B4 B 03454CF8 <- Avalon is started, dongle reset
FB0002 W 00000010
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028
FB0002 W 00000028 <- retained value, all others were discarded
FB00B4 B 00000D60 <- new check
FB0002 W 00000010
FB0002 W 00000028
FB0002 W 00000028
...Speaking of reversed... No offense but... IIRC one time my brother inserted the dongle upside down, it got hot but fortunately it recovered from this... So I need to ask...: is it possible that you put the dongle upside down?troed wrote: 18 May 2020 22:43Just a hickup, but irritating. It does give me some incentive to in addition to emulator support also try to produce either a working GAL16V8 replacement or, if the equations cannot be reversed from the data, some MCU based hw clone.beel1 wrote: 18 May 2020 22:38 Now you have a fried dongle, so at least they were right about the fact that they are not eternal, but still... I'm really sorry for you :(
/Troed
Yeah I do think that's what's happened - although by the previous owner. The plastic tabs were already broken on the cartridge and the PCB could've easily been put back upside down. I've tested it in another ST I have and in its current condition it gets hot when put in correctly as well.beel1 wrote: 18 May 2020 23:25Speaking of reversed... No offense but... IIRC one time my brother inserted the dongle upside down, it got hot but fortunately it recovered from this... So I need to ask...: is it possible that you put the dongle upside down?
Tomorrow I will check the Gnd-Vcc resistance on mine
