Page 4 of 8
Re: Tf534 problem with IDE speed
Posted: 23 Feb 2020 13:24
by kulamario
I have 1mb chip ram
Now most games and demos start working
When I come back from work I'll check this mad professor
Posted: 23 Feb 2020 13:40
by supaduper
kulamario wrote: 23 Feb 2020 13:24 I have 1mb chip ram
Good stuff if Mad Professor Mariarti runs then you have cracked it, do not worry about Defender of the Crown 2 as this will be WHDload related not hardware related
Also regarding Settlers , there are lots of different WHDload versions and many have problems so have a search on the forums for a working one for your setup
Posted: 23 Feb 2020 15:34
by terriblefire
Sounds like you cracked it.
Posted: 23 Feb 2020 16:24
by kulamario
Lads if I buy 030 50mhz should work 50mhz on TF534?
Posted: 23 Feb 2020 17:38
by alenppc
kulamario wrote: 23 Feb 2020 16:24 Lads if I buy 030 50mhz should work 50mhz on TF534?
It's very unlikely that you'll be able to run at 50 mhz if you are using the spec'd 55ns ram. 40 is about the max you'll get out of those.
Posted: 28 Feb 2020 18:38
by kulamario
Memory what I use is
AS6C8008-55ZIN
it took me some time to check everything
And case looks like this
Not so many games work on whdload if some game already works it only for a moment and goes to workbench
But if I run games from gotek all games work perfect
So I think is something wrong is with my system
Posted: 29 Feb 2020 00:56
by terriblefire
You might need to set the no autovector stuff in WHDLoad.
Posted: 29 Feb 2020 10:20
by kulamario
i setup already
Posted: 01 Mar 2020 02:35
by kulamario
What Classic WB you use?
And what kickstart you have?
I have 3.1 40.63 and Classic WB Full from my Amiga 1200 - now I install Litle we ill see
Posted: 01 Mar 2020 12:34
by kulamario
I install classic WB version litle
Still have problems
Now even I have white screen
Dnt know what could be wrong
Please give me some advice
I add all my errors what I get
