Page 4 of 4
Re: H4 schematic
Posted: 15 Jan 2020 21:53
JezC wrote: 15 Jan 2020 21:48 I'm guessing you are still in the dark re when they pre-assembled boards will be returned to you?
yep :( aint gonna be anytime soon by looks of it.
Re: H4 schematic
Posted: 15 Jan 2020 22:00
by JezC
exxos wrote: 15 Jan 2020 21:53 yep aint gonna be anytime soon by looks of it.
:cry: :mad: :cussing:
Re: H4 schematic
Posted: 10 May 2020 12:21
by terriblefire
Noticed that FARNELL contain RS links.
Played a bit of havok with my code to try and extract boms for each supplier out of the master file.
ALso noticed Farnell urls in RAPID columns
... also seeing in rows 194-200 *USE ABOVE in the MOUSER Column... mouser spat the dummy at that .
Re: H4 schematic
Posted: 10 May 2020 16:27
by terriblefire
This is a BOM that can be uploaded to Mouser and gets almost all of the simple items.
mouser.csv
(1.63 KiB) Downloaded 310 times
Then for the items that are out of stock on mouser (or v expensive) you can get the remainder of the passives via rapid..
rapid.csv
(469 Bytes) Downloaded 271 times
Rapid is a bit crap with BOM management.
So there are still parts not obtained but thats the Lion's share.
Re: H4 schematic
Posted: 16 May 2020 17:29
by terriblefire
I understand that this isnt available anymore but is this the part required for the Cartridge port?
https://www.mouser.co.uk/ProductDetail/ ... %2FkXP4%3D
Re: H4 schematic
Posted: 16 May 2020 17:50
terriblefire wrote: 16 May 2020 17:29 I understand that this isnt available anymore but is this the part required for the Cartridge port?
Not enough info to say.. but most connectors are 2.54mm.. the ST used 2mm which I already looked into it loads.. There is something which *just* works, but not right angle, and 2mm to short.
I assume the ST ones were all custom Atari jobs.
Re: H4 schematic
Posted: 16 May 2020 18:06
by terriblefire
exxos wrote: 16 May 2020 17:50 Not enough info to say.. but most connectors are 2.54mm.. the ST used 2mm which I already looked into it loads.. There is something which *just* works, but not right angle, and 2mm to short.
Ah ok. Then probably need to make a custom order with Sullins etc. Assuming that we're trying to completely recreate the ST.
Re: H4 schematic
Posted: 16 May 2020 18:09
terriblefire wrote: 16 May 2020 18:06 Ah ok. Then probably need to make a custom order with Sullins etc. Assuming that we're trying to completely recreate the ST.
I think you gave me the info where you got the Amiga connectors from, but like you said before, and I think they want to deal with individuals as I never heard back from them.
Re: H4 schematic
Posted: 16 May 2020 18:10
by terriblefire
exxos wrote: 16 May 2020 18:09 I think you gave me the info where you got the Amiga connectors from, but like you said before, and I think they want to deal with individuals as I never heard back from them.
I may get Mrs TF on this case then. She's good at this sort of thing.
