Page 4 of 14
Re: PCB Build - Progress - Post your Pics here :-)
Posted: 08 Sep 2018 16:04
by Icky
Atarian Computing wrote: 08 Sep 2018 15:07
Had a productive day. Missing the floppy cable and a 7402 and the Blitter (oh and the reset switch). Also need a RAM card. Other than that it's pretty much done. I haven't inspected my soldering. I can already see problems. I had soooo much flux goo that I had to clean it with IPA. So I'll go through everything carefully a couple of times. That was so much fun!
:coolpics:
Great work - my day set aside for soldering has not happened yet. Life gets in the way.
Posted: 08 Sep 2018 16:12
:lolbig: :bravo:
Those big caps should probably be lay flat :)
I wouldn't bother with the blitter for now anyway :)
Posted: 08 Sep 2018 18:45
by Atarian Computing
exxos wrote: 08 Sep 2018 16:12
:lolbig: :bravo:
Oh, right. Didn't think of laying them down. Oh well.
7402 installed.
I found this. Will it work standalone and what do the jumpers do?
- IMG_0288.jpg (2.51 MiB) Viewed 6182 times
Posted: 09 Sep 2018 11:47
Atarian Computing wrote: 08 Sep 2018 18:45
I never used that type of stuff, probably best idea is to install it on a working stfm and play about with it..
Posted: 09 Sep 2018 18:36
by Icky
Almost there. Need to go round and do a bit of tidying up on my soldering (its been pretty rubbish to start with but getting better after hours of it) and check for any shorts.
Now waiting on a few more components to help with the build such as SIL sockets for the resistors and the long header pins to fit the Exxos Falcon Ram board.
Have been keenly watching all you others build yours and adapting according to suggestions etc.
- MIDI Socket mod (see second pic) - cut the front pins off and soldered some pins through and soldered to the ground plate
- Reset switch onto a header to fit the holes
- Laying flat the large capacitors
- IMG_3025.png (2.38 MiB) Viewed 6124 times
- IMG_3027.png (490.75 KiB) Viewed 6124 times
Posted: 11 Sep 2018 18:27
by Icky
I wonder who is going to breathe life into one of these boards first.
- 030-gene-wilder.jpg (60.18 KiB) Viewed 6054 times
Atarian Computing and I have been discussing about how would we go about first turn on. Its that first flick of the switch that is the nervous moment.
Final checking of boards is key I was just looking over Atarian Computing's pictures and I noticed I put my YM2149F in the wrong way round. :oops:
Check, check and check again.
Unfortunately I am not going to be able to get back onto my board until Sunday.
Posted: 11 Sep 2018 18:31
Icky wrote: 11 Sep 2018 18:27
50:50 for a totally black or white screen :P
Plus 50% chance of some chip getting hot for no reason, and 50% chance someones bad soldering is to blame :P
Posted: 11 Sep 2018 18:47
by PhilC
Ah, don't worry about your sound chip, I soldered the rom socket the wrong way round :shock: Fortunately, the chip still fits in it
It won't be me first unfortunately, still got lots of small components to solder up.
Good luck guys, really looking forward to seeing what happens.
Posted: 11 Sep 2018 21:03
by Realloy
Almost done with mine some connectors and the develish resistors in RGB and some touch up and overlook of all the solderings
- Upload.png (697.09 KiB) Viewed 6036 times
- Upload2.png (640.39 KiB) Viewed 6036 times
I solved the keyboard connector
Posted: 11 Sep 2018 22:39
Realloy wrote: 11 Sep 2018 21:03
:bravo:
Seems you guys are rocketing along with it all!
I'm going to send my board off to be assembled, see if I can catch up a bit as there are a few getting close to power up now...
