Page 30 of 51
Re: TF1230 Beta Interest (Open Source)
Posted: 14 Sep 2021 10:49
by supaduper
Ok so I was having loads of probs CF not working then working Blah Blah blah, so in the end I swapped out the Ram and the CPLD and Viola ! its all 100% working so must have damaged my cpld with all the strangling lol
all cf cards work, cheap and nasty and the top brass ones too its all good, well happy.
wow a TF1230 for the A1200 under £100 ( without CPU and Depending on ram size) ,who`d av thunk it, Fantastic work Mr Leary 8-)
Posted: 14 Sep 2021 11:38
by arkadiusz.makarenko
terriblefire wrote: 14 Sep 2021 09:57
Has anyone tried the TF IDE drive yet? it should work exactly like the TF1260 with the ehide.device.
My amiga crashes when running loadmodue ehide.device
Posted: 14 Sep 2021 11:44
by terriblefire
arkadiusz.makarenko wrote: 14 Sep 2021 11:38
Crashes or reboot? its supposed to reboot.
Posted: 14 Sep 2021 11:47
terriblefire wrote: 14 Sep 2021 11:44
Crashes, but need to check if after keyboard reset it is ok.
Posted: 14 Sep 2021 11:48
by terriblefire
arkadiusz.makarenko wrote: 14 Sep 2021 11:47
I will check with Erique if there is 060 code in the driver or something.
Posted: 14 Sep 2021 12:09
terriblefire wrote: 14 Sep 2021 11:48
Ok. So what happens it simply doesn't reset correctly, but after manual keyboard reset it loads driver fine.
I managed to load SysInfo from external ide, and i got this
- 16316177630927532159512648667869.jpg (287.45 KiB) Viewed 3385 times
Posted: 14 Sep 2021 12:46
by terriblefire
arkadiusz.makarenko wrote: 14 Sep 2021 12:09
Ah then we might have a soft reboot issue like the TF330r2
Ok so it works we just need to make it fast.
Posted: 14 Sep 2021 12:53
by supaduper
ehide device boots fine with me and keyboard softboot works also , and the speed is not too shabby, and always give the partion a different number as I see you have duplicated a device number ( The one with the under_score ) normally not a problem but it will stop confusion :)
- ZbkIdDb.jpg (243.59 KiB) Viewed 3297 times
Posted: 14 Sep 2021 13:48
by Lemaru
supaduper wrote: 14 Sep 2021 10:49
I guess that'll be the rough pricing for an assembled board from a builder? And rough cost for a build it yourself (including CPU) is under £80
Posted: 14 Sep 2021 14:00
by kulamario
Twice time amiga frozen in EBM
- 20210914_001044.jpg (76.69 KiB) Viewed 3356 times
