Page 30 of 61
Re: V2.5 BOOSTER CURRENT PROTOTYPE STATUS (SEC BOOSTER)
Posted: 19 Jan 2019 23:41
by rpineau
@PaulJ : I stand corrected :) (I'm always happy to be wrong, it means I'm learning :) ).
Glad to see other programmer being able to JTAG these devices.
Posted: 20 Jan 2019 03:48
by PaulJ
Rpineau, not an issue, happy to be challenged. :)
Posted: 20 Jan 2019 22:49
by pakman
exxos wrote: 18 Jan 2019 21:45 I can donate a board if anyone wants to build one up, but will need a Atmel programmer.
I have no idea how long it will take to debug the odd faults though.
I would like to get one!
PCB with 68000 SEC assembled, nothing else.
I will do my tests with a Lattice CPLD, where I have all tools (compiler, programmer) available.
Unfortunately not pin compatible, so it will need some extra wiring..
Posted: 20 Jan 2019 22:59
pakman wrote: 20 Jan 2019 22:49 I will do my tests with a Lattice CPLD, where I have all tools (compiler, programmer) available.
I can send you a PCB.. but I think trying to force wire a different PLD would require much more effort than just creating a new PCB to fit your lattice PLD...
Posted: 25 Jan 2019 13:21
So using a stencil is a bad idea on the PLD then...
Onto the fun part... :roll:
Looking a bit better now...
I really need to find a easier way of doing this stuff :roll:
So onto the CPU next.. then its in the US cleaner before I do anything else...
Posted: 25 Jan 2019 15:02
Bit better results. I did solder a Videl on a Falcon last year this way without issues.
Still didn't go perfect though...
Did a crappy short video..
Its going in the US to clean up next before I get sticky fingers!
Posted: 25 Jan 2019 16:14
by PhilC
Is the clear stuff flux? I've not tried adding that to the inside, just solder paste but the needle for the paste is a bit too big, so I end up having to use desoldering braid to remove the extra.
Posted: 25 Jan 2019 16:19
Forgottenmyname wrote: 25 Jan 2019 16:14 Is the clear stuff flux?
yep.
Forgottenmyname wrote: 25 Jan 2019 16:14 I've not tried adding that to the inside, just solder paste but the needle for the paste is a bit too big, so I end up having to use desoldering braid to remove the extra.
Yeah braid I use a lot of, and flux. I sent the last boosters off to be assembled for me as just can be doing without the hassle these days. I'm only doing this one myself as I got a bit of free time next week so want to see if I can diagnose the odd faults I keep seeing.
Posted: 25 Jan 2019 16:36
by PhilC
Well good luck then. Just ordered myself some Atmel Gals as my PAK still doesn't work and I know everything else on it does.
Hope you have better luck that I have so far.
Posted: 25 Jan 2019 19:20
Now to see if the PLD is found.. then onto doing some simple test firmware (pinout is different than last build so have to do some tweaked firmware :roll: )
.. and some capacitor soldering voodoo...
