Page 30 of 39
Re: STFM case remake
Posted: 18 Apr 2021 08:43
by Icky
terriblefire wrote: 18 Apr 2021 00:09
At the risk of going off topic... what are the chances @icky might consider making a case for the TFMSeX?
Funny you were mentioning that
@terriblefire. It did cross my mind for a brief second about an MSX case but there are many variations of MSX styles, also finding the time.
Posted: 18 Apr 2021 08:53
by Icky
Slowly, slowly something is rising. Didn't have any hiccups over night, the Giant Panda is performing well so far. Am seeing a couple of areas that can be improved :)
- IMG_0045.jpeg (37.1 KiB) Viewed 4798 times
Posted: 18 Apr 2021 09:03
by derkom
I see you are using "standard" support structure there. Have you played around at all with tree supports? At least using Cura's slicer, I've found that the tree supports are far easier to remove afterwards, and leave a significantly nicer surface on the model.
Posted: 18 Apr 2021 10:13
by Icky
derkom wrote: 18 Apr 2021 09:03
Its the accordion type structure that pulls off pretty easily. I haven't yet got to try out the tree supports as I haven't yet found time to switch slicers to use it. The tree structure does look a nicer way of supporting though.
Posted: 18 Apr 2021 10:36
How come not printing on its top ? Then the posts would be vertical..
Posted: 18 Apr 2021 10:59
by Icky
exxos wrote: 18 Apr 2021 10:36
Laying it flat has issues with the grill part as the initial edge is just 1 line wide so the adhesion is not that great.
EDIT: As mentioned earlier in the thread am playing with a snap in grill and the pillars as separate components that screw on. This will make printing even more easier.
For this print i wanted just to see how it all came out and what needed adjusting.
Posted: 18 Apr 2021 11:01
by Icky
Now you have me playing with Cura
@derkom :)
Posted: 18 Apr 2021 11:12
Posted: 18 Apr 2021 11:19
by derkom
Icky wrote: 18 Apr 2021 10:59
girl
Do tell. :shock: (emphasis mine)
Now you have me playing with Cura @derkom :)
I'm fond of it. I've played with a few slicers, and Cura is my favourite. I may be a bit biased because my first printer was an Ultimaker Original+, so Cura was the natural fit. But I've tried a few others since then, and I keep coming back.
Posted: 18 Apr 2021 11:23
by Icky
derkom wrote: 18 Apr 2021 11:19
girl
Darn autocomplete - should say grill :)
