Page 275 of 339
Posted: 22 Aug 2023 15:18
rubber_jonnie wrote: 22 Aug 2023 15:13 16Mhz failed at EXACTLY the same point. 2376 folders left and 23510 files left.
I'm going to try to finish it again, but this time at 8Mhz, since last time it finished fine at 16.
Very odd. Maybe it's a clue again :shrug:
What I thought it was some sort of speed issue because it is always the folder names which are corrupted.
I did create a large folder amount only, like 1,000 folders to delete, but I did not see any problems with that. But I did not do a lot of testing with folders only.
So I guess if you have time give that one a try ? maybe even copy them several times for 7,000+ folders to test.
FOLDERS.zip
(136.86 KiB) Downloaded 44 times
These files may work better.
https://www.exxosforum.co.uk/forum/view ... 20#p104135
All the files are around 1K. So lots more files and folders, so greater chance of it failing.
Posted: 22 Aug 2023 15:28
And it's a big fat nope:
@8Mhz it died after a short time. I didn't see any folder/file name corruption this time.
Posted: 22 Aug 2023 15:29
rubber_jonnie wrote: 22 Aug 2023 15:28 And it's a big fat nope:
So was that "folders only" test ? Not sure which fileset your using ?
Posted: 22 Aug 2023 15:35
exxos wrote: 22 Aug 2023 15:29
No, that was the original set of test folders for all of my tests.
I have just run a 99 cycle DMA test on my MSTE with my test harness and all cycles passed. I'm running it again now with 1000 cycles, but I doubt the result will change.
Posted: 22 Aug 2023 15:37
rubber_jonnie wrote: 22 Aug 2023 15:35 No, that was the original set of test folders for all of my tests.
:thumbup:
I guess one course of action which could work, if anyone has a TF536/ST536 who could create a large RAM disk and copy my test files to it and delete . This way it would rule out the entire DMA system then, as it would be all within RAM.
Posted: 22 Aug 2023 15:43
Second test, ironically crashed in exactly the same folder name!
2010 - 984 = 1026
3308 - 1600 = 1708
1708 + 1026 = 2734 total files and folders.
It is mighty coincidental as it exactly matches the folders and files it deleted before when it crashed! (2734) .
I will connect the Pico drive backup so I can copy the folders only again and try a large amount next.
Posted: 22 Aug 2023 15:45
by dad664npc
deletion completed - did not bomb-out
STe / 2MB RAM / TOS2.06 / HDDriver 11.13 / Blitter disabled / fold220
will test again with blitter enabled now
Posted: 22 Aug 2023 15:47
dad664npc wrote: 22 Aug 2023 15:45 deletion completed - did not bomb-out
That coincides with my findings so far as well then.
Posted: 22 Aug 2023 16:08
exxos wrote: 22 Aug 2023 15:37
:thumbup:
1000 cycles completed with no error, running 2000 now. I'll test just the folders once thats done.
Posted: 22 Aug 2023 16:11
rubber_jonnie wrote: 22 Aug 2023 16:08 1000 cycles completed with no error, running 2000 now. I'll test just the folders once thats done.
:thumbup:
I'm deleting 8009 folders currently.
They all deleted just fine.
:dizzy:
