Page 28 of 32
Re: Mac Classic - will it ever run again!!
Posted: 07 Jul 2023 21:25
by olivier.jan
I can send you a known good disk image if you want to try. Just need to find a way to transfer 2GB…
Posted: 07 Jul 2023 23:08
olivier.jan wrote: 07 Jul 2023 21:25
That would be amazing, thanks.
Posted: 10 Jul 2023 09:25
So, after some investigation at the weekend, I decided that the resistor I'd previously reflowed to get the expansion card working still looked iffy.
There is a small cluster of resistors, which includes R10 that I'd previously reflowed:
- PXL_20230710_080433964-edit-20230710090529.jpg (258.29 KiB) Viewed 2876 times
This isn't my actual board, but a donor board, but it shows R10-R13 clearly. Looking very closely, the soldering on all 3 remaining resistors seemed suspect, and I wondered if what had caused the damage to R10, had also done similar, but less visible damage to the others.
Since I have 2 other donor boards, I decided it was time to pull them all off and replace from one of those spare boards.
So far, it ran for about 6 hours yesterday afternoon/evening with no signs of a fault. I'm running another test today, and if all is well, I will try BlueSCSI again with an image kindly suppled by
@olivier.jan and see if I have any more success.
Fingers crossed!
Posted: 10 Jul 2023 09:34
by stephen_usher
:dualthumbup:
Posted: 10 Jul 2023 13:02
Well, so far it's been running since just before 09:00 and all is well, and that is with the case on so I'm feeling positive.
Posted: 10 Jul 2023 13:48
@olivier.jan
It boots from BlueSCSI - kind of:
- PXL_20230710_124451401.jpg (192.25 KiB) Viewed 2854 times
It get's this far and crashes, even with shift held down, so I wonder if the SE/30 specifics are giving it a hard time. Whilst it's working, I may well see if I can prep the disk and re-install my own copy of System 7, since I know it sees and boots from your disk image.
EDIT: No, I still can't initialise the disk, however this is definitely progress, since I now know that it'll actually boot from the drive.
Posted: 10 Jul 2023 13:58
by stephen_usher
It's probably a 68030 kernel, which won't run on a 68000.
Posted: 10 Jul 2023 13:59
stephen_usher wrote: 10 Jul 2023 13:58
Yep, I was thinking the same.
I may see if I can build a disk under Basilisk for Mac Classic, see if it'll boot.
Posted: 10 Jul 2023 16:20
Hmm, interesting.
I found a 2GB image containing OS 6.0.8l which actually booted just fine, but I tried to upgrade it to 7.0 and it did it, but crashed on boot. Strange. Going to try yet another SD card to see if it's that that's the problem.
Posted: 10 Jul 2023 16:38
by olivier.jan
When you try to initialise the disk, what kind of message do you get ? Which software do you use to initialize ?
If you haven't tried already, here are the two file for setting up the HD.
First expand the Apple_HD_Setup until you have a Mac 68k executable.
Expand the patch and apply the patch, then you can run the Apple HD Setup and it will work on any SCSI HD, not only the one sold by Apple.
Also, make sure to have your Volumes < 2Gb.
!Message from: Moderator
@olivier.jan, we have placed your attachments in-line so they display correctly in your post. Here's the
how-to guide.
