Page 28 of 39
Re: New project: An ACT Apricot F1 "barn find"
Posted: 16 Jul 2021 09:56
by stephen_usher
New PCBs to play with!
- IMG_2368.jpg (160.84 KiB) Viewed 3060 times
Posted: 16 Jul 2021 18:42
by stephen_usher
Phew! The new power supply for the monitor works.
I'll have to solder the wires properly over the weekend.
Posted: 16 Jul 2021 20:59
by stephen_usher
OK, it's too hot up in the room upstairs to do proper soldering but I couldn't help doing the monitor PSU properly.
All happy.
- IMG_2370.jpg (92.3 KiB) Viewed 3033 times
- IMG_2369.jpg (21.09 KiB) Viewed 3033 times
Oh, and I added a knob onto the stalk of the brightness control. From pictures it looks like the original always breaks up and falls of and none have the original knob fitted.
Posted: 17 Jul 2021 10:37
by stephen_usher
Jolly retro-brighting weather...
Do do do do do-do.
- IMG_2372.jpg (99.01 KiB) Viewed 3013 times
Posted: 17 Jul 2021 11:34
by stephen_usher
The Mk.II boards are now made up.
- IMG_2373.jpg (56.47 KiB) Viewed 3008 times
I'll probably have a look at testing them after lunch. I can by-pass the ATTiny85 socket with a jumper for the first test.
Posted: 17 Jul 2021 12:05
by stephen_usher
You know, I dispute those who say retrobrightening is merely a bleaching chemical reaction as I can always tell when the brightening has finished for the day when the plastic suddenly lightens (within 10 minutes) and the cream starts to take on the colour of the browned plastic, almost as if it's a leaching effect.
- IMG_2374.jpg (50.69 KiB) Viewed 3004 times
Posted: 17 Jul 2021 12:44
by stephen_usher
And the retro-brightening result?...
- IMG_2375.jpg (38.28 KiB) Viewed 3000 times
Not quite the original colour (the rear shell hadn't discoloured) but close enough. It was originally slightly darker orange than the base.
It doesn't look too bad now. At least you can see the logo easily!
- IMG_2376.jpg (55.14 KiB) Viewed 2999 times
(It looks less yellow in person.)
Posted: 17 Jul 2021 14:26
by stephen_usher
The new boards work, though I gave myself a bit of a scare when I didn't ground the output going to the OR gate for STEP as that was floating high and causing the machine to sort of crash.
Anyway, it reads floppies at the standard rate now.
- IMG_2377.jpg (102.08 KiB) Viewed 2986 times
- IMG_2378.jpg (79.54 KiB) Viewed 2986 times
Having said that, I should have made the daughter board a bit shorter, I was paranoid about having chips underneath the power supply. So, instead the floppy cable connector now fowls the top of the controller chip. Well, it's good enough.
The next part of the development entails learning how to program the ATTiny85 correctly (and creating a two core wire between the daughter board and cable converter board so as to be able to monitor Motor-On and which drive is selected).
Posted: 17 Jul 2021 16:34
by stephen_usher
Well, well. It seems that I won't need the ATTiny85 after all and all my previous failures with a second drive were all due to the floating ground pins on the previous cable adapter.
Lookie here... Booting off drive B: which is a real floppy drive!
- IMG_2379.jpg (67.79 KiB) Viewed 2974 times
Posted: 17 Jul 2021 17:41
by stephen_usher
Bother! It's unreliable.
If the machine correctly detects two drives at boot then everything works flawlessly. However, if it doesn't then it ignores the second drive even over resets (warm) as it never checks again.
OK, ATTiny85 definitely needed then.
