Page 27 of 36
Re: The latest member of the family
Posted: 26 Feb 2025 17:31
by Maximilian
Posted: 26 Feb 2025 17:38
by alexh
That was the technique in the late 90's early 00's but CF cards have not worked like that for a long time. And you need a PC with a native PATA port that can run DOS.
Posted: 27 Feb 2025 19:37
OK so the Amiga is fully recapped, just waiting on the SD card adapter and then fingers crossed it can all go back together.
Posted: 28 Feb 2025 13:20
Allegedly Evri are delivering my SD to IDE adapter today, between 14:30 and 16:30. Fingers crossed it'll work as expected and I can get the Amiga buttoned up over the weekend.
Posted: 28 Feb 2025 21:25
Well the SD to IDE adapter arrived and it works brilliantly :)
So this weekend I really need to get my 3d Printer out and try to run off a Gotek housing!
Looking very positive for getting it buttoned up over the weekend :)
Posted: 01 Mar 2025 10:45
OK, so the Amiga is reassembled and working fine. The SD card solution is way better than the CF card and is 4GB so very happy with that.
- IMG20250301103325.jpg (330.05 KiB) Viewed 424 times
- IMG20250301103334.jpg (329.16 KiB) Viewed 424 times
There's a couple of caveats though. First off, I've not sorted the Gotek yet. It's a bit more complicated than for the ST so I'll either see if I can mod the external drive to be bootable or get round to the Gotek later. I suppose booting from the external Gotek isn't so much of a thing as long as I can have an external one for installing whdload onto the HDD.
I also need to fit a switch to turn off the IDE interface, and I need to get some parts for that.
In the meantime I need to have a bit of a tidy so I can pull the Atari 400 apart and have a look round inside.
Very happy with the outcome though, 8MB fastram plus 1MB of chip RAM and 4GB of HDD.
Posted: 01 Mar 2025 12:30
by PhilC
It's a good feeling when you can finally put the case back together and call it done.
Posted: 01 Mar 2025 12:41
PhilC wrote: 01 Mar 2025 12:30
Yeah, it sure is.
Posted: 01 Mar 2025 14:31
by JezC
Glad you enjoyed your purchase @rubber_jonnie
Posted: 01 Mar 2025 14:34
JezC wrote: 01 Mar 2025 14:31
It's great :) Thank you.
