Page 253 of 302
Re: General Stuff(tm)
Posted: 09 Dec 2025 21:14
by stephen_usher
And Spectre GCR seems fully operational!
- IMG_4817.jpeg (172.61 KiB) Viewed 526 times
- IMG_4818.jpeg (202.15 KiB) Viewed 526 times
- IMG_4819.jpeg (185.7 KiB) Viewed 526 times
This is the first time since 1991, when I bought the TT, that Spectre has ever run on this machine.
Posted: 09 Dec 2025 21:37
:bravo: :2k2:
Posted: 09 Dec 2025 22:24
by stephen_usher
The NetUSBee still refuses to work, but the timing on that may need more than a nanosecond or two adjustment.
Posted: 11 Dec 2025 13:37
by stephen_usher
Just as an experiment I fitted 2.2K pull-ups on the data lines, which was tricky as the pin spacing on the connectors is 2mm and not 2.54mm.
Although the NETUS.TOS diagnostic now reliably saw 0xffff when trying to read the non-existent USB chip (as opposed to 0xfffa with sometimes 0xfcfa, suggesting that the internal pull-ups aren't strong enough) the NetUSBee-Lite still isn't working.
The problem probably is a timing one then, with the generated /DTACK being too early, before the chips have output data onto the bus.
Posted: 11 Dec 2025 21:47
by stephen_usher
Well, I can pretty well pin it down to bad reads now, probably due to timing.
uiptool.tos manages to initialise the ethernet chip, read its ROM (which will be fast) and blindly send DHCP packets to the network, but it doesn't see the reply. I see the DHCP request packet on the net.
Posted: 12 Dec 2025 17:11
by stephen_usher
Just as a last test I upgraded to the very latest MiNT kernel and added the ne2kenec.xif driver, not thinking that it would help but...
- IMG_4820.jpeg (94 KiB) Viewed 447 times
The NetUSBee-Lite network only goes and starts working!
It doesn't work under UIPTOOL though. However, it's amazing that it does actually work at all.
Posted: 15 Dec 2025 22:29
by stephen_usher
I may have "accidentally" won the auction on an Atari 800XL...
Posted: 15 Dec 2025 22:42
stephen_usher wrote: 15 Dec 2025 22:29
Oooh nice, what sort of condition?
More details soon please :)
Posted: 15 Dec 2025 22:55
by stephen_usher
Looks a bit rough but not too bad. No idea if it works. Probably more fun if it doesn't.
https://www.ebay.co.uk/itm/157530564121
Posted: 16 Dec 2025 11:40
by stephen_usher
Oh dear. The seller is sending the machine via Evri.
https://www.bbc.co.uk/news/articles/ceq107yxxjyo
