Page 25 of 66
Re: exxos's DFB1 trials
Posted: 17 Nov 2022 14:58
Badwolf wrote: 17 Nov 2022 14:56 That's not a trace, that's the oscilloscope monster's fangs!
It seems the does that when it crashes. I do see some relative good clock switching when it is running but difficult to capture. But even so I don't know why that would happen at 50MHz anyway. Should be pretty much a passthrough from the oscillator ?
Posted: 17 Nov 2022 15:04
by Badwolf
exxos wrote: 17 Nov 2022 14:58 It seems the does that when it crashes. I do see some relative good clock switching when it is running but difficult to capture. But even so I don't know why that would happen at 50MHz anyway. Should be pretty much a passthrough from the oscillator ?
Wait, that's the CPUCLK output line?
You need to get the CLKOSC input line on the second channel, then. It looks like it's trying to produce a 66% duty wave.
Posted: 17 Nov 2022 15:10
Badwolf wrote: 17 Nov 2022 15:04 Wait, that's the CPUCLK output line?
Yep.
Badwolf wrote: 17 Nov 2022 15:04 You need to get the CLKOSC input line on the second channel, then. It looks like it's trying to produce a 66% duty wave.
But it only does that when it crashes.. It looks fine when it is switching between 16Mhz / 50MHz otherwise.
I'm currently trying to figure out why locks up at 50MHz in the first place.
Posted: 17 Nov 2022 15:27
The plot thickens once again :roll:
Posted: 17 Nov 2022 15:35
by Badwolf
I think you're only seeing it when it crashes as when it crashes it presumably ends with no bus cycle happening, so switches up full-time to 50MHz.
The obvious thing to question is whether CLKOSC input is actually getting down to 0V now or if it's floating up & therefore we're not getting a symmetrical signal.
exxos wrote: 17 Nov 2022 15:27 The plot thickens once again :roll:
The top one looks relatively normal (other than the slow cycle is on the low branch -- I must have inverted it from DSTB1). The bottom one is starting to see that 66% duty cycle appaering again.
What does the input look like as this is happening?
Posted: 17 Nov 2022 15:38
Badwolf wrote: 17 Nov 2022 15:35 What does the input look like as this is happening?
What input are you referring to ? The oscillator ? that is fine..
Posted: 17 Nov 2022 15:46
by Badwolf
exxos wrote: 17 Nov 2022 15:38
The CPLD-side of the oscillator's TUNE resistor.
Between the 33 and the PLD.
There's a schmitt trigger on the PLD's clock input, so any input oscillator floating away from ground at the bottom of its duty would produce a skewed duty cycle internally.
Posted: 17 Nov 2022 15:50
by dml
Can the oscillator be ac-coupled through a small cap before the 33R resistors? Not sure what is normally done here but does suggest there is some kind of dc offset there?
[EDIT]
Actually any ac-coupling cap would need to be after those other caps, as those can charge up to a dc offset.
[EDIT]
On seconds thoughts, no that's rubbish - they won't average a DC offset if has been taken out beforehand. Pff.
Badwolf wrote: 17 Nov 2022 15:46 Between the 33 and the PLD.
Looks the same both sides of the resistor.
Something else has gone wonky somewhere :( either there has been a bad connection develop or something else is broken because it seemed to be running at 50x less speed just.. The clock is still switching away.. Bizarre..
Posted: 17 Nov 2022 15:54
Oh after about 10 minutes it did the first dash on TOS's boot up RAM test :lol:
