Page 23 of 48
Re: BLITTER RE-CREATION THOUGHTS
Posted: 14 Oct 2019 00:30
Icky wrote: 11 Oct 2019 21:40 Didn't work. As soon as you turned on the Blitter it froze.
Damn. Maybe we should bodge on a 32mhz osc into the shifter and run the same clock to the FPGA board ? It could just not like out of sync clocks...
Posted: 14 Oct 2019 07:45
by Icky
exxos wrote: 14 Oct 2019 00:30 Damn. Maybe we should bodge on a 32mhz osc into the shifter and run the same clock to the FPGA board ? It could just not like out of sync clocks...
Or I could mod my STF Remake Alpha to accept the FPGA Blitter and use the 16MHz mod to put everything back to stock 8MHz and feed the Blitter the 32MHz line.
Posted: 14 Oct 2019 08:27
Icky wrote: 14 Oct 2019 07:45 Or I could mod my STF Remake Alpha to accept the FPGA Blitter and use the 16MHz mod to put everything back to stock 8MHz and feed the Blitter the 32MHz line.
Yeah, but sounds more work than bodging a osc onto the shifter...
Posted: 14 Oct 2019 08:53
by Icky
exxos wrote: 14 Oct 2019 08:27 Yeah, but sounds more work than bodging a osc onto the shifter...
True, haven't had my caffeine this morning. Although the FPGA board is 3.3v so will need a 5V <-> 3.3v buffer for that line.
Posted: 14 Oct 2019 08:58
Icky wrote: 14 Oct 2019 08:53 True, haven't had my caffeine this morning. Although the FPGA board is 3.3v so will need a 5V <-> 3.3v buffer for that line.
You may find by the time the shifter is loaded, and go via a 33R that you may well end up with 3V output on it anyway.
Posted: 14 Oct 2019 09:03
by Icky
exxos wrote: 14 Oct 2019 08:58
I’ll take a look tonight :)
Posted: 15 Oct 2019 11:15
by Icky
Just thought I would share some videos of the FPGA Blitter Board running using the stock code at different clock speeds and the effects it has.
Running @ 8MHz
Running @ 16MHz
Running @ 32MHz
Posted: 15 Oct 2019 13:11
by dhedberg
Icky wrote: 15 Oct 2019 11:15 Just thought I would share some videos of the FPGA Blitter Board running using the stock code at different clock speeds and the effects it has.
Running @ 8MHz
Running @ 16MHz
Running @ 32MHz
What about 64MHz? :lol:
Posted: 15 Oct 2019 13:12
dhedberg wrote: 15 Oct 2019 13:11 What about 64MHz? :lol:
:chairsmack:
Posted: 05 Nov 2019 17:01
I have been looking at the schematics again today, and still confused over some of the logic.. For example..
Sure its a FlipFlop, but why 2 clock inputs, They are just C and /C driven by a inverter elsewhere. Normally C would latch on the falling edge, and /C Would latch on the rising edge. But this one has both. I've noticed this funkyness all over with other blocks as well. I think only 1 clock is needed, but no way to know what edge its supposed to latch on :shrug:
