Page 23 of 124
Re: REV 3 - The beginning
Posted: 06 Apr 2021 22:30
by terriblefire
You need slow, keepio and change keeper to float
Posted: 06 Apr 2021 22:37
terriblefire wrote: 06 Apr 2021 22:30 You need slow, keepio and change keeper to float
Done that, made no odds.
Posted: 06 Apr 2021 22:39
by terriblefire
exxos wrote: 06 Apr 2021 22:37
Well dunno. i never had issues with ram on the ST... worked fine. :)
Posted: 06 Apr 2021 22:42
terriblefire wrote: 06 Apr 2021 22:39 Well dunno. i never had issues with ram on the ST... worked fine. :)
No hope for me then :) only works if I invert the RAM clock.. TTRAM does drop a bit in speed, 903% to 847% or something like that.
Posted: 06 Apr 2021 22:46
by terriblefire
exxos wrote: 06 Apr 2021 22:42
is your ram clock set to 100Mhz, 50mhz or CPU clock speed...
Posted: 06 Apr 2021 22:50
terriblefire wrote: 06 Apr 2021 22:46 is your ram clock set to 100Mhz, 50mhz or CPU clock speed...
CPU CLK50M, RAM ~CLK100M
Posted: 06 Apr 2021 22:51
Current scores...
Posted: 06 Apr 2021 22:58
by terriblefire
exxos wrote: 06 Apr 2021 22:50
Hmmm. Yeah leave it like that if its working then... i think later boards i have CPU and RAM at same clock rate.
Posted: 06 Apr 2021 23:04
terriblefire wrote: 06 Apr 2021 22:58 Hmmm. Yeah leave it like that if its working then... i think later boards i have CPU and RAM at same clock rate.
Looks like 847% is the "proper" speed anyway... Mine must have been running too fast for some reason to get 903% originally.
https://www.exxosforum.co.uk/forum/viewt ... 975#p42329
Posted: 07 Apr 2021 10:48
by Badwolf
exxos wrote: 06 Apr 2021 22:04 Finally looking how things are supposed to be :thumbup:
When high it is either accessing ROM or TTRAM... If it is pulsing low, it is accessing the ST bus.. which is not all that often now :)
Yes! That's *got* to be the tipping point.
Should not have been seeing all those AS30s on the ST side.
:dualthumbup:
