Re: REV 3 - The beginning
Posted: 06 Apr 2021 10:45
If I run all the conditions through the master clock it does improve things greatly, but if I use a slower clock then does not boot up :roll:
We welcome retro users & hardware gurus alike! Come and join the party :)
https://www.exxosforum.co.uk/forum/
Is blue still ST-AS there? Why's it pulsing in between what appear to be normal bus accesses?exxos wrote: 06 Apr 2021 09:36
But more bonkers things going on, address strobe is high and DTACK is clearly pulsing when there is no possible way it could even do that.. unless I am missing something ?! there is no blitter or anything else on this machine I don't see how DTACK Is being driven. The PLD only has DTACK as a input, so I cannot see how the chip can even be driving that as a output unless the compiler is seriously screwing up somehow. I did have a span of the software ringing of a blank page for the design summary, intermittently not seen the PLD, and after a while it would not even let me copy and paste in the thing.. I think the more you use it the more it starts screwing up.
Both scope probes are on the 68K socket.. Because the code wasn't isolating ST_AS from AS30.. It is actually both ST_AS and AS30..Badwolf wrote: 06 Apr 2021 11:45 Is blue still ST-AS there? Why's it pulsing in between what appear to be normal bus accesses?
To me that looks like blue is actually 030 AS and this is behaving perfectly normally with a load of 50MHz accesses (causing no DTACK) and then the occasional ST-RAM access (blue goes low followed ~250ns later by yellow both then terminate at the same time).
Wouldn't know how to do one even. Anything I can see a little odd is ST_DTACK does not always register as a high just before it locks up.. But it should not really affect anything anyway.terriblefire wrote: 06 Apr 2021 13:29 do you have a simple simulation of the code? I usually find the problem when i do that
email me the code. Bit busy this afternoon but i'll see what i can doexxos wrote: 06 Apr 2021 13:32 Wouldn't know how to do one even. Anything I can see a little odd is ST_DTACK does not always register as a high just before it locks up.. But it should not really affect anything anyway.
ok will do thanks.terriblefire wrote: 06 Apr 2021 13:36 email me the code. Bit busy this afternoon but i'll see what i can do
AndresPlazaR wrote: 06 Apr 2021 13:58 Quick non-technical interruption: I just want to tell you that I have been following each post and, even if I don't understand all the interactions that you are having, I really enjoy the conversation, appreciate all your efforts and I think it is a master class of collaboration and camaraderie.
